Vtec not working :(
Old Nov 10, 2012 | 06:04 AM
egdro's Avatar
Icon3 Vtec not working :(
what up, I got a 94 ej1 with a b16a second gen with a PR3 ecu i got this problem that vtec isnt working i got check engine light codes 5,10 but i dont think that any of those codes have to do with my vtec issue, i need help plz
Old Nov 10, 2012 | 06:43 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Vtec not working :(
Did this just happen or happened since the swap?
Reset the ECU and see if both those codes return then answer the below questions:
10 is for the intake air temp sensor. Is it plugged up and if so what are the wire colors going to it?
5 is for MAP sensor, is it plugged up and if so what are the wire colors going to it?
Old Nov 10, 2012 | 05:24 PM
egdro's Avatar
well i bought the car with the swap done already it had the check engine light on but i knew that those codes were there, i know i need a new intake air temp for sure cuz it was broken when i took it off and im not sure about the map sensor if i need a new one but with that said ik i have it hooked up right because i check other threads, do those codes have to do with anything related with vtec?
Old Nov 10, 2012 | 05:26 PM
TTE TEG's Avatar
Fill the fluid.
Old Nov 10, 2012 | 05:32 PM
egdro's Avatar
what fluid? oil?
Old Nov 11, 2012 | 04:14 PM
egdro's Avatar
bump
Old Nov 11, 2012 | 05:10 PM
ScareCrower's Avatar
Check your oil, if it is low, fill it up.
Replace your oil filter.
Old Nov 12, 2012 | 03:59 PM
egdro's Avatar
ok i did this and still no result
Old Nov 12, 2012 | 04:10 PM
Technical Hero
You'll have to fix that 5 code, what are the wire colors going to the map sensor or post a pic
Old Nov 12, 2012 | 05:43 PM
hannslebo's Avatar
I don't think vtec will work with CEL 5 on.
Old Nov 16, 2012 | 05:39 PM
TTE TEG's Avatar
Originally Posted by egdro
what fluid? oil?
VTEC fluid. Sounds like it's low. My VTEC "pop" started to fade, so I changed out the fluid and now it hits like new!
Old Nov 16, 2012 | 06:23 PM
Technical Hero
He trolling you, stop being a douche. Did you ever fix code 5
Old Nov 16, 2012 | 07:36 PM
crazyridha's Avatar
Check your wiring by the ecu make sure there are no cut wires...thats what happen to my friends car same problem same codes...
Old Nov 20, 2012 | 02:59 PM
egdro's Avatar
ohh ok so i should get rid of code 5 and it should work after that?
Old Nov 20, 2012 | 03:38 PM
josephcmiller2's Avatar
Make sure you didn't accidentally swap the IAT and MAP plugs. If so, your IAT is likely fried. Good luck not stripping the Phillips screws trying to remove it.
Posted from Honda-tech.com App for Android
cleanazcoupe
Jun 27, 2009 03:17 AM
BILLisCHILL
Apr 17, 2008 05:52 AM
240r
May 16, 2007 06:58 AM
vtec25
Jan 13, 2007 08:18 AM
FleXingMyEK
Jun 2, 2003 10:31 PM
