b18b1 reving problem
Old Nov 9, 2012 | 01:35 PM
decon's Avatar
Default b18b1 reving problem
I did some searching and didnt come up with anything so gonna ask. I just did a headgasket on my LS, and replaced my dizzy with another one because some how it went bad while i was working on the car. I just took it for a short drive was like mabey 5 miles. But when i try and rev when i get to about 2000 rpm it just cuts out untill it drops down to about 1500 and keeps doing it. It will do it in gear and while just reving the engine. Car is idling fine, and i didnt notice any smoke while i was driving. any help would be awsome.
Also i have no codes..
Old Nov 9, 2012 | 01:53 PM
Fliptard's Avatar
Default Re: b18b1 reving problem
check your TPS, make sure it's plugged in and that you didnt get the TPS and MAP plugs switched around.
Old Nov 9, 2012 | 02:09 PM
decon's Avatar
thanks man ill check that, also could it be a sign my tps is gone bad?
Old Nov 9, 2012 | 05:36 PM
jreed773's Avatar
im having the same problem but i havnt checked those issues yet could it be any thing else like an electrical issue maybe
Old Nov 10, 2012 | 01:48 AM
el crapitan's Avatar
op, did you check/adjust your base ignition timing?
Old Nov 10, 2012 | 05:26 AM
decon's Avatar
Um im gonna say no, i just maked up everything befour i took it off and then used the marks when installing them all back.
Old Nov 10, 2012 | 08:02 AM
start by checking/adjusting your base timing then. both the head gasket job and distributor replacement require it.
you'll need a timing light. vehicle at operating temp, jump the service connector and aim the light through the timing mark on the lower cover. there will be 4 marks on the crank pulley. one mark on it's own, and 3 marks 14-18* before the lone mark. the lone mark is top dead center. the other 3 are 14,16, and 18* btdc. you want the light to flash on the center of the 3 marks. 16*btdc. if it doesn't, back the distributor bolts off and turn the housing until it does. make absolutely sure that you jump the service connector prior to checking and adjusting
Old Nov 10, 2012 | 08:45 AM
decon's Avatar
thanks man, i just got a timing light a few mins ago so i can do this.
Old Nov 10, 2012 | 08:53 AM
good good. there are a tonne of more detailed writ ups onthe net, or if you have your manual, follow its procedure. make sure to follow all steps. especially jumping the service connector
Old Nov 10, 2012 | 04:58 PM
decon's Avatar
thanks man
Old Nov 11, 2012 | 10:55 AM
decon's Avatar
Well just finished timing it the best i could. But weird thing is that the reving issue stopped on its own befour i timed it. dam weird car.
mrmoomoox
May 10, 2010 07:42 AM
teg4thewin
Mar 10, 2010 06:40 AM
peAches yO
Oct 9, 2007 10:30 PM
ek9child
Nov 3, 2006 09:46 PM
trooper0641
24
Jan 13, 2006 02:34 PM
