High Rpm & Bad Shift Response.
Old Nov 9, 2012 | 11:56 AM
xChrizcrozzx's Avatar
Icon2 High Rpm & Bad Shift Response.
Ok this problem is a bit hard to explain it happened with my stock motor and still happens after i swapped to a B16A2.
But basically sometimes after driving for a while my RPM idle goes to 2000rpm and i can only let off the clutch if im like pressing the gas ALOT. It makes it hard for me to cruise cause the car wasnt to take off and it only shifts well when im going fast. Sometimes turning the car OFF and back ON would stop it but whats going on?! PLEASE HELP im lost. THANKS
Old Nov 9, 2012 | 12:03 PM
jbpnoman's Avatar
Default Re: High Rpm & Bad Shift Response.
Chassis and ECU? Harness? B16A, or B16A2? What other modifications do you have?
Old Nov 9, 2012 | 12:39 PM
B16A2 ECU could be cause its stock? -_-
Old Nov 9, 2012 | 05:53 PM
jbpnoman's Avatar
Ok, since you're new, I'll try to be nice. How about you start off with the rules. Specifically, this one.
Car information
For all technical questions, the following information MUST be included in the first post: vehicle (year, make, model) and engine (if not stock, year, make, model, OBD type). Other pertinent information includes check engine light (CEL) codes as well as engine modifications, such as a turbo kit tuned at 18 psi or a specific throttle body, large injectors, big cams, etc. This information is absolutely essential because, in many instances, members wishing to help in a thread waste their time by posting detailed replies, only to find out the next day that the topic starter left out CRITICAL information. Please respect members wishing to help by taking the time to list or mention crucial information about your car.
You said "swapped". You also said "B16A" in your first post, not B16A2. There is a difference. If you expect help, you need to be clear in what you say.
Old Nov 10, 2012 | 04:59 AM
egdro's Avatar
yea bro we need more info on the car
Old Nov 10, 2012 | 03:36 PM
-_- Man this forum Crap is Confusing,
-B16A2
-Aftermarket Headers
-Short Ram Intake
-Stock ECU
-AfterMarket Exhaust
Thats About it.
Old Nov 10, 2012 | 04:10 PM
grumblemarc's Avatar
The Grumpiest
I've read the original post a dozen times and I'm having a hard time trying to picture what the issue is.
Check the TPS.
OnceIwasMuffin
May 18, 2015 02:17 AM
98layinframe
16
Dec 30, 2013 07:02 PM
Hirousuke
Apr 11, 2007 07:09 PM
