1996 D16y7 to 1998 D16y8 Parts Price list
Does this sound right for a new parts list? I found a list on another site and I started looking up new prices at AZ and this is what I have come up with...
. Part #....... Price.......Total
D16y8 Head ... 2538A.......569.99........569.99
D16y8 Intake Manifold (Performer Intake X) .. 4756.......359.99........359.99
D16y8 Throttle Body 4791........404.99.........404.99
D16y8 Fuel Rail 4798........130.99.........130.99
D16y8 Fuel Injectors .. 800-1450N........79.99.........319.96
P28 ECU ( May also use P2P ECU, I'll get into that later )
An Intake Device. ( The new setup will put the Throttle Body on it's side, not up in the air. )..
Torque Wrench 79-142..........29.99...........29.99
Head Gasket .. 1149........93.99..........93.99
Copper Spray 80697........7.99.......... 7.99
Intake manifold Gasket MS91485...........7.99..........7.99
Throttle Body Gasket .
Exhaust Manifold Gasket 1469...........26.99............26.99
Timing Belt . 95224........33.99...........33.99
Oil + Filter XG3593A..........9.99............9.99
Coolant .. AF-2100.............13.99..............13.99
96-00 Honda Civic EX Spark Plugs (4pack) . 0784-4.........19.99..........19.99
Some Wire, and Wire Connectors .
Colored 3M Tape to mark Fuel Line, Vacumn Lines, and Coolant Lines
A box of Zip Lock Bags and a Sharpie. That way you know what bolts go where ..
Total........................$2,030.83
Less discount...............$203.08
Subtotal....................$1,827.75
Taxes..........................$109.66
Grand Total................$1,937.41
I wanted to go to ARP head studs but I haven't came across that part number and price yet. I also need to source the ECU.
buy a used complete head. should not be more than $200. skip the intake manifold and just run the oem ex one.
oem headgasket.
it should not cost you more than $500 to do. if you're gonna spend 2 grand might as well do a b series swap.
oem headgasket.
No not trying to buy or sell from the market place, I was pricing out a new mini me vs a junk yard pull. New head, new intake, a new motor itself is about 1000 plus labor to R&R it. I could get a Bseries for cheaper I think but then I have to make everything fit and have to get it rebuilt and axles etc. My current engine runs great but with almost 450k on it, I want to plan on a replacement soon. I don't want to lose A/C (its hot in DC metro area) and I commute 65miles one way.
ahh that explains it. well i got my complete block+head 00' b16 with barely 100k on it for only $1000. bought the headers, IM, and such off here and spent an additional 200. pretty cheap build id say if your on a budget.
