This is a weird one - starting issues
Hello friends... Here's the deal...
My 1992 Civic DX just shut off while driving
- acted like it was out of gas
-my gauge has always been fine and it stated it was 1/4 full
- but I put alot of gas in anyways 8+ gallons
- Still wouldn't start after
- so I primed it (turning key over and over) then it fired up and was fine
HERE'S WHERE IT GETS WEIRD .....
Every morning it will not start - so I prime it like crazy
-sometimes it tries to start and sounds like the manifold is off (really deep sound) and then hella white smoke comes from under the hood -flooded?
-then it starts!
-runs amazing! better than I remember it
-I can turn the key on and off and it starts up fine
But when I let it sit overnight and rest - the next morning = nothing - dead
-I begin the long process of getting it started that one time - then it's fine
It acts like fuel is not being sent to engine - repressurize? how?
or It acts like when you take the fuel relay out and try to start - starter just winds
TODAY THE CAR IS DEAD - can't use my old tricks
Here's some history and more info
-I definitely hear the fuel pump and hear the fuel pump relay click
-Because of multiple thefts I have been pulling the ECU out -stopped when I had this new problem - figure they aren't going anywhere - won't start
-Checked the innards of the fuel pump relay to see if any circuits are burnt, looks fine - but I've been pulling it out - because of theft issue -Bad? - I've checked some of the connections with a test light and it's fine
-It's been getting cold in the mornings here
-tried to push start - not working
-changed my plugs, fuel filter, three months ago
Gonna test spark tomorrow, see if gas is being sent to filter, and check coil and dizzy
Thanks fellas - any help would be greatly appreciated
-then it starts!
Also, check your fuel pressure at the filter. You should be able to rent the tool at your local parts store. You should get 36-40PSI as soon as you turn the key to ON(II).
When was the last time the fuel filter was replaced?
Three months ago I changed the plugs,all filters , O2 sensor
is the cat still installed?
the white smoke from under the hood sounds like you exhaust manifold is cracked or you have a leak.
also could be a injector suck open.
rent the tool from the auto parts store turn on the key till you get pressure on the gauge ifyou get the 36~40 psi see how long it holds pressure. my car will hold 36 psi for days with out starting.
I didn't mention this because it didn't make sense with your problem, but while you have the tool it doesn't hurt checking. You should hold 36-40 PSI for 2 hours after turning the key to OFF, if I'm remembering service manual specs correctly, with no more than 2 PSI fluctuation.
sediment screen filter on the fuel pump may be shellaced over or clogged. Especially if any fuel additives were added to the fuel tank that might cause rust/scale in the tank to break free and clog the screen.
Fuel pump pressure check at the fuel filter may tell you this.
Sorry for the delay fellas -
Get ready for this ....
So I got a hold of a fuel pump pressure gauge
-installed it
-Damn thing fired right up with an immediate 38lbs of pressure while connected to vacuum hose and a nice 40+ with vacuum hose disconnected -per Honda manual pg. 11-105 -see attachment
-Took off gauge and reinserted bolt
-Restarted it , and it started to cough and blow white smoke and died
-tried again
-It fired up, then I let sit and idle, it eventually coughed up and died.
- I thought for sure it's the fuel filter, something must be moving around inside
So as I was getting ready to take that ***** off, I thought why the hiccup and the smoke? Maybe I'll check my distributer cap and rotor -for kicks
*** As a side note ***
I started a post a while ago -see link below
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1992-civic-dx-cannot-take-off-distrubutor-rotor-3037485/
I bought a new cap and rotor and found that the existing rotor has NO screw!
I haven't installed it because I am still wondering what the hell I am going to do.
The dilemma is ... If I somehow pry the existing one off - Will it have a screw hole?
-If it does = great! - but now I have to find the correct screw -order-ship-wait
-If it doesn't - Well every rotor I have found is made with a screw hole
-So I never installed it - thinking eventually I gotta deal with this - but...It's running now!
BACK TO THE ORIGINAL PROBLEM....
-I looked at the cap and found little pieces of S#@%T in there
-I installed the new cap and DAMN this thing runs good
-So far it's great, we will see tomorrow
Now I gotta deal with that rotor tomorrow - will keep you posted
Thanks guys
-installed it
-tried again
Thanks guys
Ken Knowles
15
Mar 25, 2021 11:02 AM
hondaboy4life
May 8, 2006 06:44 AM
