HELP PLEASE! 1993 honda civic leaking...
Old Nov 5, 2012 | 07:59 PM
bronman69's Avatar
Icon3 HELP PLEASE! 1993 honda civic leaking...
hey guys, im new to the forum and some what new to Hondas. I'm not a tech but i know my way around a car from DIY stuff in my shop.
i recently picked up a 93 civic ex coupe.(on the title under "model" it says CE? anyone know what that is?) It has a d16a block, with a p08-2 head, and a p28 ECU. (anyone heard of this motor? i was told it was a JDM motor?)
It was leaking ALOT of oil, to the point it would leave a puddle. So i changed the dizzy o-ring, vtec solenoid gasket, and oil pan with a new gasket. That helped the puddling of oil but still dripping oil. I know the camshaft seal has to be replaced too.
so im still leaking oil on the backside of the motor somewhere (firewall side). i have wiped it down dry to and find this stubborn leak. next day oil is on the ground, transmission bell housing, driver side axle(which is always wet. Passenger side is dry), and on in underside of the intake manifold.... when i drive it for more than ten mins and stop it will smoke right where the exhaust manifold meets the cat....
im stumped could the transmission be leaking somewhere? the transmisson is stamped "s20"
Thanks guys for any help, much appreciated!
Old Nov 5, 2012 | 08:01 PM
PLAGUED_DB7's Avatar
Default Re: HELP PLEASE! 1993 honda civic leaking...
Best thing to do at this point is drain all your fluids. The leaks will stop
Old Nov 5, 2012 | 08:41 PM
D-Vice's Avatar
wow dude that sounds like a lot of leaks.
was the previous owner a tweaker? Just kidding.
If you're leaking from the backside like that, first thing I would check, make sure someone didnt double gasket your oil filter. Also check the oil sensor located near the oil filter to make sure it wasn't loosened. Never know when people put in oil pressure gauges, then remove them again upon selling a car.
Old Nov 5, 2012 | 08:46 PM
bronman69's Avatar
yea i know i can drain all the fluid and it will stop haha. and yes the dude before me didnt know ANYTHING about cars, he didn't even know that the spark plug wires came off... ok i willl check those two things tomorrow when i get it on my lift. Could a oversized sized oil filter do that? or could the axle o-ring be bad? i know the axle clicks once its in the transmission.
Thanks for the help
Old Nov 5, 2012 | 08:47 PM
10psiLsEf2's Avatar
PICS?
Old Nov 5, 2012 | 08:50 PM
D-Vice's Avatar
yeah an oversized filter could do that.
And yeah the axle seal on the transmission can drop a good amount of oil.
Old Nov 5, 2012 | 09:54 PM
bronman69's Avatar
ok, thanks. i will get pics up tomorrow around 1pm pacific time
cause i was thinking what else could fling oil up to the intake manifold.... lol
Old Nov 6, 2012 | 01:28 AM
HondaPartsHero's Avatar
Technical Hero
-oil pressure switch (green sensor)
-oil filter
-breather box o ring #9
Old Nov 6, 2012 | 07:43 PM
bronman69's Avatar
im trying to post pictures.... its hard lol
Old Nov 6, 2012 | 08:33 PM
10psiLsEf2's Avatar
not showing up i see X!!!!!!!!!
Old Nov 7, 2012 | 07:44 PM
bronman69's Avatar
Icon3 Re: HELP PLEASE! 1993 honda civic leaking...
I think i got them!! lol sorry for the delay im retarded.... let me know if these are good enough!
Old Nov 7, 2012 | 07:45 PM
bronman69's Avatar
dont know why the pictures are so small though... idk if you can see if the block stamp d16a
Old Nov 8, 2012 | 05:00 AM
andyz's Avatar
Get a case of carb cleaner. And some oil leak dye and. Ultraviolet light.
Old Nov 8, 2012 | 07:36 PM
bronman69's Avatar
yea that was my next step, its mostly the drivers side axel and bottom of the transmission is wet... just wondering what else could make that side wet other then a main, or an axle not seating properly...
Nikita Davis
Sep 17, 2016 02:37 AM
elc0lomb1anito
Sep 1, 2009 04:14 PM
playacjm5
Jul 23, 2009 12:10 PM
92redhatch
Aug 27, 2006 09:52 AM
renzema
Mar 30, 2005 07:53 PM
