Transmission & Drivetrain Gearboxes, Differentials, Clutches
1999 accord wont go into reverse.
Old Nov 5, 2012 | 08:47 AM
boosted95si's Avatar
Default 1999 accord wont go into reverse.
all other gears work fine. i checked the clutch fluid and linkage seems ok. theres a small box onto of the tranny that the linkage goes into. should i take that apart maybe a pin fallen out or something.
Old Nov 5, 2012 | 09:41 AM
David @ Synchrotech's Avatar
Default Re: 1999 accord wont go into reverse.
Usually when an Accord or Prelude manual trans will not engage reverse it is due to a worn 5th-Reverse slider sleeve getting stuck on the hub. This will require a rebuild to fix.
Old Nov 5, 2012 | 09:45 AM
i appreciate the reply. is it normal for this diagnosis to have 5th work normaly ?
Old Nov 5, 2012 | 09:48 AM
also if i take it out i found a used tranny for 300$ should u just swap it out or buy the parts and rebuild the old one. i rebuild twin countershaft 18s at work im sure i could hadle this little guy just dont wanna go spend 250 on parts when i could spend 50 more n save some time.
Old Nov 5, 2012 | 10:01 AM
You never know what you are getting with a used trans. The rounded engagement teeth are from grinding while shifting to 5th but 5th can still work even with a worn sleeve. The sleeve set is only about $150 if you want to tackle the job.
Pmartos24
Mar 24, 2015 10:06 AM
cawb352
Classic Hondas
Nov 29, 2010 07:51 AM
HondaMizzan
Sep 14, 2009 09:53 PM
Rhev
Jul 22, 2009 03:35 AM
jdm_DC2R
Nov 6, 2005 09:58 AM
