Cam sprocket install info needed...
Old Oct 18, 2002 | 07:46 AM
Nate B's Avatar
Default Cam sprocket install info needed...
Can any of you guys give me a link to a site with a Helms breakdown or similar page with info. on installing cam sprockets. I tried c-speedracing.com but they don't have the info I need. And Helms website doesn't show a breakdown on the procedure. I ordered my Helms manual but it wont be here for another week or two and I'm gonna try and drop the sprockets in tonite. Any ideas?
Old Oct 18, 2002 | 07:53 AM
Chris N's Avatar
Default Re: Cam sprocket install info needed... (TypeR#1111)
Nate,
I'd borrow a helms. I'd give you mine but I'm taking off tommorrow morning for gingerman. Didn't find anything on here? i don't know if you are meeting up with dave and scotty on sunday, but I think dave has installed cam gears. I'm sure he's got more experience with this than you or I have, since he installed those zex cams in his hatch. Maybe those two jokers could help you get them in on sunday....
Old Oct 18, 2002 | 08:03 AM
Nate B's Avatar
Default Re: Cam sprocket install info needed... (1107)
I'm gettin together with Scotty on Sunday and Dave is supposed to come out as well to do some suspension work. Neither of us have heard from him lately so I don't know what's goin on. I figure there's gotta be a website somewhere with a detailed breakdown of the whole process.
Old Oct 18, 2002 | 08:08 AM
Chris N's Avatar
From a post in an old post by racebrewer that I found:
I put my own cam gears in. It is not that difficult! ! !
Here are a couple things I did that will make it easier.
Remove sparkplugs so that engine can be turned over easily. I used a 19 mm wrench on the power steering pump to turn over motor. At one point I also had to use a 14 mm wrench on one of the cam bolts to get by a sticking point.
After valve cover removal. I made sure that the cams were at top dead center by making sure that all the marks on the cam gears lined up. Also the ignition timing mark on the crank was lined up at TDC.
The cams can be pinned at TDC by dropping long pins (allen wrenches, for example) through two of the four holes in the long aluminum plates that hold the tops of the cam carriers in place. The other two holes don't line up with anything.
CHANGE ONE GEAR AT A TIME!
Tie wrap the other cam gear to the belt so there wont be any slippage! Now cams are pinned in place and one gear is locked to belt. Not much can go wrong now.
As a safeguard, I used a crayon and put a couple marks on the cam belt that lined up with the TDC marks on the original pulleys. The TDC marks on the new pulleys should line up with these marks. You'll immediately know if something has gone wrong!!!!!!!! (Clever, huh?)
When you remove the stock gear(s) there is an asymmetric woodruff key between the cam gear and the cam to lock it in place. It is VERY easy for this key to drop out and fall behind the plastic belt cover. I removed the gears and put a dab of wheel bearing grease into the woodruff key slot and then replaced the key. Grease should keep it from falling out. I also took an old off-white (Ha!) t-shirt and slid it in under the gears so that anything falling would land on the cloth and not behind the plastic belt cover.
Do visual checks to make sure that the woodruff key is in place after you slide the hub in place and before putting the hex head capscrew back in place. The woodruff key is not a full half-moon and it MUST be put back the same way.
Before I put the new gears in place I dis-assembled them so that I was only working with the center hubs. This made it much easier to install the hubs. The outer gear wasn't fighting with the belt then. It made it easier to tell when the hub slid home and when I torqued the capscrew in place I knew that I was getting a proper torque (41 foot lbs). You must use a torque wrench!
Slide the cam gear pulley into place on the hub and tighten down the screws that hold it in place. Double check that everything is at TDC. Tie wrap the belt to the new pulley and then repeat with the other pulley. Double check on the belt tightness and reassemble plugs and valve cover. Done.
I also use Dow Corning Vacuum Grease (see an industrial house to re-seal the valve cover, etc.
Old Oct 18, 2002 | 08:12 AM
Chris N's Avatar
Some info here about cam gears, too.
http://www.c-speedracing.com/howto/caminstall/cam2.html
Old Oct 18, 2002 | 08:14 AM
Nate B's Avatar
Thanks Chris, I owe you a cold
Old Oct 18, 2002 | 08:15 AM
baonest1's Avatar
sup, i have a helms. what do you need to know. ill see if i can help. ill try to scam a page if needed
oh and be very careful if u do it yourself, if u mess that timing up then your cams will snap, mine snapped in 2 places.
[Modified by baonest, 12:15 PM 10/18/2002]
Old Oct 18, 2002 | 08:20 AM
Nate B's Avatar
Default Re: Cam sprocket install info needed... (baonest)
are there recommended tourqe settings in the helms book?
Old Oct 18, 2002 | 08:36 AM
Chris N's Avatar
Yes. (I dont' have mine handy)
Old Oct 18, 2002 | 08:39 AM
Nate B's Avatar
Well what good are you then?
williamdte
May 3, 2004 07:24 PM
dabomb
Oct 10, 2003 08:43 PM
ih8danoles
12
Mar 26, 2003 06:00 AM
acatak
Jan 23, 2003 09:39 PM
