Need advice! 95 Civic EX Coupe!
I recently purchased a GBP 95 Civic EX Coupe (5 speed)
I picked it up for 1660 with 117,000 original miles.
The plan was to use as a daily and winter beater so my 06 rsx type s could stay cooped up and get rid of it right after the winter, but now I'm decided whether its worth it to fix some stuff up, keep it for a little while, and sell it for more. Only problem is I need to figure out if it's worth it.
I have a buddy that will fix all the body work (honda cancer) and repaint it for $500 which puts me at about 2100.
Also since the last owner took the air box off and stuck a wrong sized aftermarket air filter in the stock hosing, I would need an intake which I'm guessing will be anywhere from $30-$70 depending on where I get it.
Since the shifter is super loose I'm assuming I need to replace the spring pin as well as the shifter bushings (which would be a good time to get a short shifter) this will run me roughly $70 as well is what I'm assuming.
Currently has chrome hub caps so I need to get wheels/tires which could be $150 or more
Also I saw a "dress up kit" that replaces all the bolts in the engine bay with stainless steel ones for a little over $100 which now I'm thinking isn't even worth it but I did want to replace them because my stock ones are rusted.
I may need to do a couple small things here and there as well.
Do you guys think this is worth it? All this stuff is roughly an $800 investment and could get a little higher depending. That means I spent $2400 which I don't know if I would get back on a car like this. With all the work and stuff I would want to get at least $2500-2700 back from the investment.
Really want your suggestions, see if you would do anything different or what not. Let me know, all help is appreciated.
NoGreenCard
Sep 27, 2004 12:06 PM
