Rotors, quick question
Old Oct 18, 2002 | 07:35 AM
fangtl's Avatar
Default Rotors, quick question
Can someone tell me what the dimples are there for?
Old Oct 18, 2002 | 07:37 AM
Philly_NBP_R's Avatar
Default Re: Rotors, quick question (fangtl)
prolly the same reason people cross drill rotors - to for cooling, and to eliminate the layer of gas/deposits (somebody help me here) that can build up between the pads and the rotor.
btw - these would be overkill for the street. I wonder if the dimples make the rotor stronger vs a normal cross-drilled disk...
Old Oct 18, 2002 | 07:42 AM
JPP's Avatar
JPP
Default Re: Rotors, quick question (Philly_NBP_R)
except I don't think the cooling is improved with these.
Yes the disk themselves would be srtonger (or less subject to cracking) then cross drilled disk
Old Oct 18, 2002 | 07:45 AM
Doctor CorteZ's Avatar
looks.
Old Oct 18, 2002 | 07:49 AM
fangtl's Avatar
Default Re: Rotors, quick question (JPP)
Then the question should be why didn't the manufacture drill all the way through? instead they leave this slight dimple on the surface...
Old Oct 18, 2002 | 07:52 AM
neither does anything benefitial.
Old Oct 18, 2002 | 07:54 AM
Ricky Rojales's Avatar
Just get ordinary Brembo blanks... much better.
Old Oct 18, 2002 | 07:55 AM
benmasters's Avatar
Default Re: Rotors, quick question (Doctor CorteZ)
I run these on my DC2 which are very similar to the disc above. What make is that?
The blind drilled holes break down surface gases when braking from speed but do not weaken the rotor cross section as can happen with through drilling, thereby lessening the chance of rotors cracking over time and heavy use.
http://www.ebcbrakesuk.com/Automotive.html
They Do make them look good thats for sure.
[Modified by benmasters, 4:58 PM 10/18/2002]
Old Oct 18, 2002 | 07:56 AM
drumsy's Avatar
New User
Default Re: Rotors, quick question (benmasters)
Advanced Auto Parts rotors own me.....
Old Oct 18, 2002 | 07:58 AM
JPP's Avatar
JPP
Because the disk with dimple would be less subject to craking compare with the disk with drilled holes, regardless of the actual usefullness of the dimples.
[Modified by JPP, 12:01 PM 10/18/2002]
Old Oct 18, 2002 | 08:18 AM
fangtl's Avatar
Default Re: Rotors, quick question (George Knighton)
<sigh> I bought these under the speculation that these are blank rotors, instead they sent me these things. BTW, I would love to buy those expendable Autozone/Advanced Autoparts/NAPA rotors, unfortunately they want to charge me $88 for my particular application. These on the other hand, were only 53 dollars shipped.
Old Oct 18, 2002 | 08:42 AM
That sucks. But, look on the bright side - they make good door stops.
DJP
Mar 8, 2008 05:39 PM
1994PreludeSi
Oct 19, 2007 10:51 PM
DelsolioGSR1996
Sep 4, 2006 05:14 PM
..::91TEG-G2::..
Nov 24, 2005 02:12 PM
Bcuz
14
May 19, 2005 07:33 AM
