Intermitten ABS light
Old Nov 3, 2012 | 03:11 PM
beocop's Avatar
Default Intermittent ABS light
Hi,
I have a 95 Accord EX 2.2L that is having ABS light problems. The problem is very intermittent and only comes on upon starting. The error code is 1-8 (high pressure).
Here is what I have tried so far:
I have tried bleeding the ABS multiple times. There were no air in the system. The error would be solved immediately (ABS light would go out) after each bleed. If it comes on/off upon start-up, it would stay that way the entire drive.
Since the problem is intermittent, I don't know the cause. Could there be debris in the system that block the passages? I only get clear liquid every time I flush the ABS. Do I have to flush the regular brake lines too? Is there some sensor that I can check?
Thanks for all your help.
Old Nov 10, 2012 | 09:06 AM
beocop's Avatar
Default Re: Intermitten ABS light
Bump. Please help me out. This problem is driving nuts.
Old Nov 10, 2012 | 10:09 AM
jdowen2's Avatar
Have you cleared the code? If not, disconnect the battery for 5 minutes, reconnect, see if code is clear.
Old Nov 11, 2012 | 07:41 AM
beocop's Avatar
If I bleed the ABS and clear the code the ABS light will clear. However, it comes back intermittently.
If I don't clear bleed/clear the code the ABS light will remain the entire time the engine is on. The next time the engine is turned on, the ABS light might clear or stay on.
All I know is that during its initial check upon engine startup, the ABS system would sometimes find a fault (probably high pressure error).
As I indicated, it is an intermittent problem so I don't know what the exact problem is and how to correct it. I am just guessing that there is some debris in the system that sometimes would not allow the valve to close to maintain pressure during initial startup. There is no leak or motor overrun.
It's all during initial system test upon engine startup.
Old Nov 11, 2012 | 11:54 AM
HonBeer's Avatar
Replace the $1.88 accumulator O-ring. That should take care of the code. Requires removal of the ABS unit (to access bolts for accumulator underneath).
Old Nov 12, 2012 | 08:20 AM
Fred Demara's Avatar
I'm going to try this...my ABS light come on very randomly...then goes off on re-starts.
Old Nov 12, 2012 | 04:15 PM
beocop's Avatar
Let me know if it solves your problem. I don't have a leak so I don't think it's the accumulator o-ring.
Old Nov 13, 2012 | 04:17 AM
forted's Avatar
Since its a high pressure code there is a chance it could be a bad pressure switch or an internal problem with the accumulator assemble. I would say try to find an assembly in the junk yard.
bonstokLS
Mar 30, 2014 10:51 PM
mikey1968
Nov 9, 2010 07:10 AM
DUHC
Aug 21, 2009 11:19 AM
DoHcV-tEc
Feb 25, 2008 10:30 PM
Havokgsr
Oct 1, 2002 03:25 PM
