Major problems fuse 14
Old Oct 30, 2012 | 02:39 PM
gnxpro24's Avatar
Default Major problems fuse 14
Hey guys I have a 97 Prelude and am experiencing some issues. I'm really good at wiring, I even make my own tuck harnesses, but this one has me stumped. The alternator went out about 2 weeks ago so I replaced it. Then 4 days ago the alternator went out again along with fuse 14. Took the alternator to auto zone and it failed all tests, so I bought a brand new one. Installed it and replaced the fuse....... 5 times. Every time I would drive the car or let it idle for about 4 minutes the fuse would blow. Took it to auto zone to get it tested and the blk/yellow wire under the dash by the computer fried. I replaced the bit of wire and unplugged both fuse boxes to check for anymore bad wiring, plugged everything back in and now the car won't start. Can't even hear the fuel pump prime. What do I do?
Old Oct 30, 2012 | 03:57 PM
gnxpro24's Avatar
Default Re: Major problems fuse 14
Anyone? This is my daily driver
Old Oct 30, 2012 | 06:39 PM
yroachy's Avatar
What wire was burnt? You aren't giving us much info. Get a wiring diagram to see what runs off that fuse, and start tracing your wires. You got a massive stereo killing your alternators?
The helms manual has trouble trees for troubleshooting electrical issues. I would look there.
Old Oct 30, 2012 | 08:36 PM
gnxpro24's Avatar
Here's what the wire runs and fuses through fuse 14. http://www.preludeonline.com/f60/nee...iagram-246845/ I can't find a helms manual anywhere local and don't have a way to order online
Old Oct 31, 2012 | 02:29 PM
yroachy's Avatar
Well there's a long list attached to that fuse. There are a lot of under hood wires there, so I'd start looking around your engine bay for some damaged wiring. One of those sensors or solenoids could also be shorted. Start with them all unplugged and plug them in one by one till the fuse blows. You could also hook up an ammeter while doing this.
EDIT: There is a link to the helms manual in the FAQ section of this forum.
Old Oct 31, 2012 | 07:35 PM
gnxpro24's Avatar
The link doesn't work. Also it won't blow the fuse since it only did it when the car was running and now it won't start.
Old Oct 31, 2012 | 09:30 PM
gnxpro24's Avatar
Now fuse 4 ACG-s fuse (whatever the hell that is) blows as soon as you try to replace it. So now I have two fuse issues
Old Nov 2, 2012 | 11:17 AM
gnxpro24's Avatar
Anyone?
Old Nov 2, 2012 | 05:19 PM
gnxpro24's Avatar
ACG fuse doesn't blow with main relay unplugged but it does as soon as you plug one in. Ive tried 4 different relays.
Old Nov 2, 2012 | 07:20 PM
yroachy's Avatar
There is at least one short somewhere. You gotta find it, we can't find it for you over the Internet...
Old Nov 2, 2012 | 07:47 PM
sigsr01's Avatar
All the wires you tuck, make sure there isn't any wire/s that open. I am sure you tape it good, but it could come loose. If your method of wire tuck is that way, cutting wires and connect them (I personally wouldn't do that), then I would go from there. gl.
Old Nov 2, 2012 | 07:58 PM
Hidenplanvew's Avatar
Apparently not as good at wiring as you thought, Find a wire diagram.. In not going to spoon feed you but use goggle and type in free helms honda... Appartly you have some bad shorts so that smashes your braging
Old Nov 2, 2012 | 08:04 PM
gnxpro24's Avatar
First of all I didn't do a fckn wire tuck on this car its totally stock. Second none of the cars I've ever tucked or made a wire tuck harness for have had any problems. So that rules out your theory, smartass
Old Nov 2, 2012 | 08:52 PM
sigsr01's Avatar
You made it sound like it. BTW calm down, just want to help.
Old Nov 3, 2012 | 08:33 AM
If you were good at wiring the first thing you would of done was get a wiring diagram and started chasing wires..
Old Nov 3, 2012 | 12:42 PM
gnxpro24's Avatar
I am good and I ordered the Oem electrical troubleshooting manual just waiting for it to arrive
Old Nov 3, 2012 | 12:47 PM
gnxpro24's Avatar
I just thought about this. Three weeks ago my car kept dying so that led me to discover that the 90amp battery fuse was replaced by the owner with a broken piece of wire. When we went to jump the car, the jumpers were already hooked up to my battery, my friend touched the negative jumper to their own positive which is what fried the first alternator. Last week that alternator took a **** along with the fuse 14 so I replaced the alternator with a brand new one. I'm guessing the whole reverse jumper situation is what started all this Bullshit but then again makes me wonder why the previous owner had blown the battery fuse.....
Old Nov 4, 2012 | 01:49 PM
gnxpro24's Avatar
Anyone?
Old Nov 4, 2012 | 02:09 PM
gnxpro24's Avatar
Newest update. I jump the service connector and it won't throw the code it has stored also will not allow an obd2 scan tool to work
Old Nov 4, 2012 | 05:07 PM
lazlong's Avatar
^^ It's gonna be a short/open or a fried ECU.
A week and nobody gave him the link to the free manual downloads? You guys are losing it.
gnxpro24
Aug 17, 2019 10:05 PM
ThatOne02Accord
Jan 24, 2013 02:50 PM
_skitzo_
Jun 3, 2007 08:16 PM
cory1269
Mar 16, 2004 08:52 AM
Jinxed
Dec 11, 2003 10:33 AM
