GSR Rear disk brakes...
Old Oct 30, 2012 | 11:54 AM
TORTUGA's Avatar
Default GSR Rear disk brakes...
Hey guy's, just wanted to know if there's a step to step guide on how to install some GSR rear disk brakes onto my 96 Honda Civic (hatchback).
Thanks in advance
Old Oct 30, 2012 | 12:04 PM
h22ekguy's Avatar
Default Re: GSR Rear disk brakes...
do you have the stock brakes in now? i can make you a step by step guide with pics later today i have VW brakes but its the same thing really.
Old Oct 30, 2012 | 12:21 PM
TORTUGA's Avatar
Yeah i got stock front brakes in the front and in the back i just have drums, but i got some gsr rear disk brakes sitting in my garage that i wanna put on.
Thanks man.
Old Oct 30, 2012 | 01:01 PM
UrbanDiplomat's Avatar
Thanks in advance
If you've got the complete trailing arm assemblies, all that's left is the brake booster, master cylinder, e-brake cables, and 4040 proportioning valve from the same donor car. It's not as simple as slapping on the parts you currently have. I mean, you can, but your e-brake cables won't work and you won't be getting enough brake fluid or pressure to the rear.
Old Oct 30, 2012 | 01:04 PM
JuggerNaut-CTR's Avatar
I did everything but the master cylinder on mine and it brakes fine...would still like to upgrade to a 15/16 or 1" though
Old Oct 30, 2012 | 01:07 PM
I know the Monrovia Pick-A-Part had a bunch of Hondas and Acuras lying around less than two weeks ago. I'd check there.
Old Oct 30, 2012 | 01:21 PM
nealnanoHX's Avatar
As long as you got the rear brakes with the trailing arms and everything it is a direct bolt in swap. You will need a E brake cable from a hatch with rear disc though like a 92-95 Si, I dont think the Integra one will work, I know it does on coupes but not on a hatch. On 96-00 Civics you dont need to replace the prop valve since all 96-00 share the same one, even the Si with rear disc. There is also no need to replace the master cylinder either the stock one will do just fine. I have not replaced mine when I did the rear disc swap and I have no braking issues. I may go to a 99-00 Si or GSR master in the future just for a little more squeeze on the brakes.
Old Oct 30, 2012 | 01:28 PM
Yeah, what ^he said, lmao.
Old Oct 30, 2012 | 01:43 PM
Ej8_KiD's Avatar
96-00 do not share the same prop valve , this has been covered before.
Old Oct 30, 2012 | 01:57 PM
TORTUGA's Avatar
Okay so basically i would just need a different prop valve? I've heard that the 91 EX Sedan will work fine, is that true? Or what else is recommended?
Old Oct 30, 2012 | 02:38 PM
nealnanoHX's Avatar
Really all are the same with the exception of the ABS models which are all AT so who cares. OEM Honda part number for 96-00 Civic all models (Lx, Dx, Ex, Hx, Cx) 46210-S04-902, Part number for 99-00 Si 46210-S04-902.
You dont need to swap anything but the rear brakes themselves leave the stock master and prop. You cant use a 91 prop valve they are plumbed different than the 96-00.
Old Oct 30, 2012 | 03:36 PM
98civdx's Avatar
Master Detailer
You don't need to change the MC for rear disk. Only if you change the front calipers.
Old Oct 30, 2012 | 04:01 PM
Yes that is true...i did fronts and rear from a gsr, still using the cx booster and m/c, brakes fine. Should have stated it was all 4 lol
Old Oct 30, 2012 | 04:32 PM
TORTUGA's Avatar
Okay thanks a lot for all the inputs
Old Oct 30, 2012 | 04:38 PM
98civdx's Avatar
Master Detailer
lol
The CX MC will still push enough to stop the car just fine.
killacam661
Feb 5, 2009 10:30 AM
b18c-ivic_gsR
24
Nov 1, 2006 06:08 PM
pootie.teng
22
Jul 12, 2006 07:27 PM
93civicsedan
14
Aug 11, 2004 01:28 PM
