b16 with an LS trans
Old Oct 18, 2002 | 01:25 AM
1tyme's Avatar
Default b16 with an LS trans
my ls just blew and i got a b16. i will still be using the LS trans. i was wondering how will the b16 do with the LS trans? are the gears too long. will be sluggish low end?
Old Oct 18, 2002 | 01:49 AM
Trooper's Avatar
Default Re: b16 with an LS trans (1tyme)
oh god yes, on a b16 avoid the ls tranny like the plauge.
Old Oct 18, 2002 | 01:55 AM
1tyme's Avatar
Default Re: b16 with an LS trans (Trooper)
why wat are the pros (if any) and the cons.
Old Oct 18, 2002 | 05:04 AM
nsxmatt's Avatar
The Ls is designed for the powerband of the ls engine. A B16 tranny keeps the enigne in vtec at redline shifts. If it doesn't do this the engine falls flat on it's face. So get a 99-00 si and shift from 1st to 3rd and 3rd to 5th and you basicly get what the ls is like. Not quite that bad but close
The pros are you will cruise as a nice rpm on the hwy
Old Oct 18, 2002 | 06:05 AM
1tyme's Avatar
Default Re: b16 with an LS trans (nsxmatt)
would a vafc help by lowering the vtec engagement point? and i'll also be adding turbo. will this help any? i only do freeway runs and i'm not really interested in 1/4 mile times, only in spanking my frenz on the freeway.
Old Oct 18, 2002 | 07:00 AM
nsxmatt's Avatar
If you have the money for a VFAC and a Turbo then just get a B16 tranny. Don't try and fool with with something just to make it work, do it right.
Old Oct 18, 2002 | 02:13 PM
1tyme's Avatar
thanks for the response but i already have a vafc and a turbo set up, that is how my ls blew. but i was wondering if this would help my situation with the ls trans, cuz i don't have money to buy another trans. i'm pretty much stuck with this set-up. let me know any opinions. thanks.
Old Oct 18, 2002 | 08:42 PM
BudaKai's Avatar
Slap the turbo on it it'll work out fine you'll have traction after every hard shift then instead of wasting tires.
Old Oct 19, 2002 | 06:16 AM
meept's Avatar
I've got the B16/LS trans combo in my '89 4dr.... 8k-rpm shifts in 1, 2 & 3 will actually stay in VTEC. Takes FOREVER to pull through a gear though. It is very nice on the highway though...3500 rpm is a nice comfortable 70-something mph cruise.
Old Oct 19, 2002 | 07:26 PM
degooser's Avatar
Default Re: b16 with an LS trans (tzsir)
AMEN to that!!!!
Old Oct 22, 2002 | 11:01 PM
xchosun1x's Avatar
Default Re: b16 with an LS trans (degooser)
in theory...it might work...but hard fact have proven otherwise....
the gears are just tooo long..and final drive is just not right for vtec motor..
i would stay away from LS trans...
Old Oct 23, 2002 | 01:49 PM
JustChou's Avatar
On a similar note...
I'm working on swapping in a B18A into my CRX, and I had heard about the incredibly tall gearing on the LS tranny. I was seriously considering a B16 tranny to mate to the LS engine...is this a common practice?
Old Oct 23, 2002 | 04:32 PM
B16CRXhybrid's Avatar
Default Re: b16 with an LS trans (JustChou)
Hey Ive got an LS tranny and Its pretty f---ing quick. You will definitely like a y1 better, but If you dont have the cash right now it will do just fine.
Old Oct 23, 2002 | 05:43 PM
JustChou's Avatar
Default Re: b16 with an LS trans (B16CRXhybrid)
Ok, thanks man.
bbrian
39
Aug 4, 2012 05:48 AM
Ratchback
Dec 23, 2005 07:42 AM
BoostedDelsol
13
Jan 22, 2005 01:37 PM
straightline
Mar 22, 2003 07:07 AM
