h22a valve lift at TDC
well the valves are opening and closing "near" tdc but they are nowhere near peak lift.
if the valves were open @ tdc not only would they hit the piston but there would be no compression.
peak valve lift occurs "roughly" around 100 degrees before and after tdc depending on the cam
i have never measured peak lift or found where it occurs on a stock cam.
Thanks, but valve clearane i can get from ESM
I meant not clearance but valve lift.
In any case I already have ordered new pistons, hope with h23 crank they will not meet valves in TDC.
you gave him opening and closing lifts @ 0 lash and then went on to say valve lash is 9-10 and 12-13
when 99% of us here refer to "lash" we are talking about valve lash (clearance between cam and rocker).
and who measures valve clearance by multiplying the rocker ratio? assuming you mean p2v or v2v clearance?
also TDC is when the piston is @ top dead center (obviously) for the cylinder in question. if you are asking about a non firing cylinder then it wouldnt be TDC, it would be referred to as BTDC and ATDC (before and after top dead center) at any given crank angle.
why are you worried about valve clearance when the piston is down in the cylinder anyway?
check your clearances while the piston is within 20 degrees either way of TDC in the firing cylinder.
you guys are confusing
Like mentioned, contact wont occur at TDC necessarily, even though this is when the piston is at its highest, due to the aggressive ramp angles of the cams. it will depend on the specific timing but common valve contact occurs if the piston catches up to the exhaust valve as its closing if I recall correct...can't remember where I heard that though. Maybe the intake valve catches up with the piston as it is accelerating away from TDC.
true his use of the word valve lash to refer to p2v clearance could be considered correct although its very uncommon for the most of us
however when you read any english written service manual or cam manufacturer specs/instructions they all use the term valve lash to refer to cam to rocker clearance (valve adjustment spec)
not a big deal, just a bit confusing
Like already mentioned, the least amount of clearance is BTDC for the exhaust and ATDC for the intake. The only time list is zero at TDC is between the compression and power strokes of the engine.
