How to change internals f22b2
your question is too vague. what are you trying to achieve? boost? all motor? what kind of budget? how much power do you want? how crazy do you want to get? daily driven or weekend car? you see where i'm going with this?
help yourself by doing some research on your own. help us help you by providing more info in your posts than just "how do i do this?"
Just trying to get a little more power out of everyday car, don't have a set budget or goal in horse power. Just wanting to go faster and not worry about tearing it up when I do. Tried researching on google but not finding much on pistons
Should search for articles on basic engine building principles & theories. Knowing how an engine works and what each part does in turn, will help you decide what parts you should be replacing.
Call a local engine builder and talk to them about what they would recommend and the cost to do the work involved.
Is this engine in your daily driver? If so I doubt that you will be able to swap out pistons in a weekend. The bottom end may require machine work that involves the block being removed from the car.
