Civic SI '93 GSR Swap won't start! HELP!
Old Oct 29, 2012 | 07:59 PM
EG92DX's Avatar
Default Civic SI '93 GSR Swap won't start! HELP!
I have a OBD1 b18c1 dropped in a Civic 93 SI right now , stock harness and all. I checked all my sensors , firing order , fuses and connections in the engine, they all check out . When I try to start the car it just cranks but doesn't catch. Help? I'll be glad to provide any info you guys need or pics to help you guys help me start the car.
Old Oct 29, 2012 | 08:01 PM
10psiLsEf2's Avatar
Default Re: Civic SI '93 GSR Swap won't start! HELP!
You need to be more SPECIFIC around here man.
Lets start with do you have
Fuel
Spark
Compression
Correct Mechanical TIMING
Old Oct 30, 2012 | 08:42 AM
NVturbo's Avatar
O.G. triple O.G.
GROUND.
Old Nov 3, 2012 | 01:19 PM
EG92DX's Avatar
Sorry, finally got time on the weekend to do anything, checked fuel , spark and compression all checks out. Still got to do timing.
I have some loose wires on my harness right now i need help i'd-ing maybe one of these wires are keeping my car from starting? My first swap bare with me!
Under the Dash:
a.
These should connect am I right? they have the same color wire pin pattern but the plugs don't connect correctly.
Driver side engine bay:
b.
c.
d.
e.
f.
Passenger side engine bay:
g.
h.
Thanks a ton! any help highly appreciated.
Old Nov 5, 2012 | 11:22 AM
jdmem205's Avatar
Yea what harness are you using?
Old Nov 5, 2012 | 06:58 PM
oversteer_ms's Avatar
Check to see if your getting fuel.
Check to see if your getting spark.
**Cant tell what most of those plugs are. The 3 wire white plug (c) is your Corner Light. The small plug (b) looks like a/c compressor. (e) Is going to be EVAP or Coolant Temp.
Old Nov 7, 2012 | 04:58 PM
EG92DX's Avatar
stock harness from SI.
Anyone have any input on plug A?
Old Nov 7, 2012 | 05:04 PM
JamesDMdb1's Avatar
what injectors? and ecu?
Ground on tstat housing?
Old Nov 8, 2012 | 10:45 PM
EG92DX's Avatar
p28 , tstat ground is good, not 100 % sure on injectors, but they plug up perfectly.
Old Nov 19, 2012 | 09:45 AM
Cheefer_EX's Avatar
Injectors were my problem with my swap. Car turned over, had spark and everything was hooked up and looked sound. If they've sat for awhile they may be plugged up with ethanol poisoned gasoline.
Old Nov 30, 2012 | 06:21 AM
EG92DX's Avatar
I'm going to try and buy some new injectors today.
Still no start guys. I just recently removed fuel tank and cleaned , forsure the gasoline has been sitting it looked yellow , kinda like **** to be honest , any idea what that might be. BTW This was a shell that was sitting . Replaced fuel pump, forsure getting fuel. Spark still there. Going to fully crack down on the compression today.
Also does anyone have the wire diagrams for all the electric under the dash?
Old Dec 4, 2012 | 11:49 PM
the171's Avatar
check to make sure the distributor rotor is pointed at cylinder #1 TDC
Cav3man
Mar 24, 2012 03:44 PM
stp_vtec_boi
Aug 23, 2006 09:06 PM
jdm2teg
Sep 23, 2005 06:16 PM
93slmdcvcsi
Dec 15, 2004 11:27 AM
