Help car wont start
Help car wont start
I hav a 1993 civic SI with a B16a3 complete swap and this morning the car wouldn't start, i recently adjusted the vavles and found out that they were a lil tight, so i re-adjusted them this morning also, and i cannot get it to start. I checked spark and i checked fuel, and it is getting both. anyone hav any ideas?
please help, i need my ride, it is my only form of transportation at the moment
Re: Help car wont start (93slmdcvcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93slmdcvcsi »</TD></TR><TR><TD CLASS="quote">I hav a 1993 civic SI with a B16a3 complete swap and this morning the car wouldn't start, i recently adjusted the vavles and found out that they were a lil tight, so i re-adjusted them this morning also, and i cannot get it to start. I checked spark and i checked fuel, and it is getting both. anyone hav any ideas?
What happens when you try to turn it over? Does it rotate or just sit there and click? Does it seem like it is trying to catch or not at all?
Do you have a kill switch? (I hate it when I get caught by that)
You have spark and fuel all thats left is timing. check your marks and see if you haven't jumped or broken a cam or something.
Re: Help car wont start (Spade)
it turns over and ever now and then it will pop like it wants to start, timing is fine, i was just driving it last night
check all ur fuses... your fuel pump may be taking a crap on you too... other than this i would spray some starting fluid and see if that works. if that works then its probably ur fuel pump.
Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">have you checked your spark plug wires for correct order?</TD></TR></TABLE>
Bam, that was my next question.
Believe it or not it may be do to your valve adjustment.
I thought I would do my own valve adjustment one day, car was working just fine before, than after I adjusted them, NADDA! It's amazing what a few hundred thousands of an inch will do.
Anyway, I got a professional Honda mechanic to readjust the valves. She started right up afterwards.
Good luck!
Good luck!
Re: Help car wont start (SweetSol)
its the valves .. for sure... can't be anything else.. if its poppin back through the manifold.. its the ur adjustment.. nothing else will cause it to do what u say its doing.. juss reset all ur valves back to stock specs.. and that sucka should fire right up.. but make sure ya adjust the valves in the order they should be... and don;t forget the feeler gauge..
mister.wong
09-13-2008 04:45 PM
