Coolant Temperature Sensor wire problem
I've noticed my temperature gauge never rising above the C mark (it used to but very slowly).
I decided to check the sensor and noticed part of the wire directly next to the connector is exposed, from what I can see it doesn't seem to be cut, just exposed
I've got a multimeter but I've never really used it before, how would I go about checking this wire to see if it's any good?
you would have to ohm the wire out from the coolant temp sensor back to the ecu to see if its broken or has to much resistance and that can be coming from the fact that the wire is open
Would I need these:https://i.imgur.com/Wq3Xi.jpg to do that? If so I'll have to go buy some tomorrow.
DaCRXboi
Aug 20, 2005 10:40 PM
VTECR021
Apr 22, 2004 08:04 PM
joey1320
Jan 19, 2004 01:47 AM
