Coolant Temperature Sensor wire problem
Coolant Temperature Sending Unit wire problem
I've noticed my temperature gauge never rising above the C mark (it used to but very slowly).
I decided to check the sensor and noticed part of the wire directly next to the connector is exposed, from what I can see it doesn't seem to be cut, just exposed
I've got a multimeter but I've never really used it before, how would I go about checking this wire to see if it's any good?
Re: Coolant Temperature Sensor wire problem
you would have to ohm the wire out from the coolant temp sensor back to the ecu to see if its broken or has to much resistance and that can be coming from the fact that the wire is open
Unplug the 1-wire sending unit and ground the wire to the engine.
Turn the key to ON(II). Does the temp gauge needle rise toward hot?
Would I need these:https://i.imgur.com/Wq3Xi.jpg to do that? If so I'll have to go buy some tomorrow.
DaCRXboi
08-20-2005 10:40 PM
VTECR021
04-22-2004 08:04 PM
joey1320
01-19-2004 01:47 AM
