TIPS/ADVICE needed for REMOVAL of STRIPPED valve cover nut.
Old Oct 28, 2012 | 08:26 AM
SteezyEG's Avatar
Icon2 TIPS/ADVICE needed for REMOVAL of STRIPPED valve cover nut.
I was going to do a valve adjustment and found that one of my nuts has the broken top end of the "stud" still in it after I took the spark plug cover off, and im not 100% sure that stud is correct word, but another nut continues to spin on top of another "stud" without coming off. The stud itself nstays still. Advice or Tips? Thank you very much, I know a lot more than some kids my age, but im only 17 and hope to get solid advice.
Old Oct 28, 2012 | 08:27 AM
Former User's Avatar
Default Re: TIPS/ADVICE needed for REMOVAL of STRIPPED valve cover nut.
Post pictures.
Old Oct 28, 2012 | 08:53 AM
SteezyEG's Avatar
The first is of the nut that continues to spin.
The following is of the broken "stud."
Engine: B16a2
Old Oct 28, 2012 | 09:15 AM
Remove the valve cover and post more pictures of the broken bolts in the head.
Bolts remaining in the valve cover are removed by prying out the seals on the underside of the cover.
Old Oct 28, 2012 | 09:29 AM
coog's Avatar
youll be able to get something onto it once the valve cover is removed
Old Oct 28, 2012 | 09:32 AM
dirty19's Avatar
Ridin Dirty in Cali
Same issue posted yesterday.
See this thread....even comes with youtube videos.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16y8-broken-valve-cover-bolt-extration-3099520/
Old Oct 28, 2012 | 10:06 AM
SteezyEG's Avatar
The top picture shows a nut that will spin, but will not come off. When using a wrench I observed that the stud was NOT moving when I spun the nut. So, without that bolt off I can't take the valve cover off. Any advice on how to remove it?
Old Oct 28, 2012 | 10:17 AM
dirty19's Avatar
Ridin Dirty in Cali
Dremel tool with a cutting disc
Old Oct 28, 2012 | 12:13 PM
SteezyEG's Avatar
What is the name of the part indicated with the arrow? It's the bolt that the washer and nut go onto.
Old Oct 28, 2012 | 12:17 PM
grumblemarc's Avatar
The Grumpiest
A bolt.
Why haven't you pulled off the valve cover?
Old Oct 28, 2012 | 12:21 PM
SteezyEG's Avatar
I already took the valve cover off. I need new "bolts" so that I can completely tighten my valve cover now that I've adjusted my valves, just needed to know exactly what they're called.
Old Oct 28, 2012 | 01:14 PM
dirty19's Avatar
Ridin Dirty in Cali
There are several online sources for honda parts manuals.
In all the time you wasted asking us you could of found it already.
Old Oct 28, 2012 | 02:23 PM
dueyx99's Avatar
http://www.hondaautomotiveparts.com/...DER+HEAD+COVER
illmatic118
11
Mar 17, 2009 09:31 AM
ITR32
Jul 27, 2007 06:09 AM
Import Prelude
Apr 18, 2007 02:50 PM
charjacq
Jan 29, 2004 04:24 PM
ActiveAero
Jun 7, 2003 02:31 PM
