Power issues help please
Old Oct 27, 2012 | 02:28 PM
Superchick9235's Avatar
Icon2 Power issues help please
My 94 1.5 has been having problems for a while... Lose of power overall but especially hill. The best I can do most times is hold 40 in second
We did some research and replaced the spark plugs, cleaned the intake,.changed the oil,.replaced valve cover gasket, cap and rotor and ran sea foam through the engine and gas tank. All this work has helped but it's still severely struggling up hill... It's great on flat ground though.
The ideas we have for our next move is replace fuel filter and maybe distributor.
Does anyone have any advice? Has this happened to anyone else?
Old Oct 27, 2012 | 02:41 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Power issues help please
How many miles on it? Have a compression test done.
Old Oct 27, 2012 | 03:01 PM
Former User's Avatar
Have you checked and adjusted the ignition timing to spec?
Old Oct 27, 2012 | 03:40 PM
I know it's low on compression but it has been for about eight months. This is a new problem. We advanced the timing by moving the cap
Old Oct 27, 2012 | 03:41 PM
135xxx miles
Old Oct 27, 2012 | 03:44 PM
Adjust the timing so that the pointer aligns with the red mark on the crank pulley. This is done with the service connector jumped. See FAQs sticky.
Old Oct 28, 2012 | 04:50 PM
Does anyone know if a thermal idle valve could be an issue?
Old Oct 28, 2012 | 08:35 PM
Checkmarks's Avatar
Super,
How low is your compression? Just four numbers and that information would let the forum see your problem.
My GUESS is for bent E valves causing crappy compression. Then guessing is not how to diagnose a car.
jdm36
27
May 3, 2011 11:31 AM
jdmhonda31558
Dec 18, 2010 05:56 PM
lexluther
42
May 24, 2009 08:47 PM
rotascircuit
Mar 22, 2008 11:29 PM
lopaka07
Jun 14, 2005 01:31 PM
