Power issues help please
My 94 1.5 has been having problems for a while... Lose of power overall but especially hill. The best I can do most times is hold 40 in second
We did some research and replaced the spark plugs, cleaned the intake,.changed the oil,.replaced valve cover gasket, cap and rotor and ran sea foam through the engine and gas tank. All this work has helped but it's still severely struggling up hill... It's great on flat ground though.
The ideas we have for our next move is replace fuel filter and maybe distributor.
Does anyone have any advice? Has this happened to anyone else?
Re: Power issues help please
Adjust the timing so that the pointer aligns with the red mark on the crank pulley. This is done with the service connector jumped. See FAQs sticky.
Super,
How low is your compression? Just four numbers and that information would let the forum see your problem.
My GUESS is for bent E valves causing crappy compression. Then guessing is not how to diagnose a car.
lexluther
42
05-24-2009 08:47 PM
rotascircuit
03-22-2008 11:29 PM
