Vtec Solenoid Issue
Old Oct 27, 2012 | 10:51 AM
EKVAVB's Avatar
Default Vtec Solenoid Issue
So my 98 ek 4 door has been recently began to leak some serious amounts of oil. Come to find out its got a 96 ex head on it ( code P2J-2 ). Well when the previous owner had this wok done they put the wrong vtec solenoid on, theres a fourth hole/port beside the bottom bolt that is only half covered. This is where all my oil has been leaking from. I just need to know what the correct solenoid is for this head.
Old Oct 27, 2012 | 12:27 PM
Former User's Avatar
Default Re: Vtec Solenoid Issue
A 96 Civic EX requires part #10 here:
http://www.hondaautomotiveparts.com/...EAD+%28VTEC%29
Old Oct 27, 2012 | 02:56 PM
EKVAVB's Avatar
Thanks alot bud !
Old Oct 27, 2012 | 03:08 PM
EKVAVB's Avatar
Although i want to say that that's the part i already had.. I want to say that this is what i need ---> http://www.ebay.com/itm/1996-1997-19...e710c1&vxp=mtr
but the bolt pattern dosen't match
Old Oct 27, 2012 | 03:12 PM
If the VTEC solenoid I posted does not fit, then you must not have a 96 D16Y8 head.
Edit: P2J-2 may come from an automatic D16Y8:
http://184.172.194.66/~wheels12/whee...topic=150295.0
But the VTEC solenoid part numbers are the same for auto and manual.
Old Oct 27, 2012 | 03:21 PM
EKVAVB's Avatar
The code on the head is P2J-2, which from what i believe i know to be a 96 d16y8 head. i just don't get why that hole on the bottom is not covered. i have that same Vtec solenoid you mentioned and it doesn't fit, is there something else i should be looking for ? im at a loss for words at this point ...
Old Oct 27, 2012 | 03:25 PM
Post a picture of your VTEC solenoid.
Old Oct 27, 2012 | 03:46 PM
EKVAVB's Avatar
Had to go take it back off aha but here you go,
[IMG][/IMG]
[IMG][/IMG]
Old Oct 27, 2012 | 03:48 PM
EKVAVB's Avatar
Brand new gasket also.
Old Oct 27, 2012 | 03:54 PM
Hmmm...the head and solenoid mating surfaces and the gasket look different from this service manual picture:
Old Oct 27, 2012 | 03:59 PM
EKVAVB's Avatar
yeah thats what i dont get, technically i have all the correct parts but they dont match up at all.
Old Oct 27, 2012 | 09:02 PM
Texas4door's Avatar
I think that picture is from a B-16...or a D16Z6
Check the pics in this thread and compare:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/vtec-solenoid-gasket-2933066/
D16Y8 and D16Z6 solenoids here:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16y8-vtec-solenoid-2921132/
Now I'm really stumped cuz I can't find a cylinder head with that hole pattern :/
Old Oct 27, 2012 | 09:13 PM
The D16Y8 and B16a2 VTEC solenoid gaskets are very similar if not identical.
B16a2 for comparison to diagram I posted above:
Old Oct 27, 2012 | 09:31 PM
Texas4door's Avatar
Are you sure (maybe I'm just tired here...)
I just checked my D16Y8 solenoid in my closet and that's the same solenoid he has going by the gasket pattern:
That wouldn't fit the B16 or D16Z6, but that's besides the point here.
I'm starting to think he doesn't have a P2J head on that thing...or at least, I can't find a good cylinder head picture with that kind of fourth oil passage
Weird custom work?
EDIT: my bad, found a decent P2J image. There IS a fourth passage there:
But what the heck VTEC solenoid gasket covers that?
Old Oct 27, 2012 | 09:36 PM
I'm not absolutely sure, but I was going by the two illustrations from the service manual that I posted.
The bottom solenoid in your first post appears to be for the D16Y8, whereas OP's solenoid is clearly different.
Edit: Now I'm worried about the service manual illustrations because the same picture is used in the 92-95 Civic service manual for the D16Z6 engine.
Old Oct 27, 2012 | 09:49 PM
Texas4door's Avatar
Nope, the top one is for the Y8 (matches with other pics on google image search)
And check this out:
http://www.d-series.org/forums/engin...l-ports-2.html
http://www.civicforums.com/forums/18...anoid-off.html
Apparently, he's not the only one with this wacky problem...that hole isn't a port at all. And I seem to recall wondering about it myself when I did my own mini-me swap a few years back (basically: wtf's the point of this thing?)
If it's leaking from there, the casting is cracked
DX
710dabber
Mar 27, 2015 01:38 PM
EKVAVB
Oct 27, 2012 11:10 AM
smacconnell
Sep 28, 2012 05:31 AM
Jay_Mills
May 15, 2012 06:45 PM
brios86
10
Mar 5, 2009 07:10 AM
