chipped p72 ecu
does anybody know what i need to do to find out what ems is running on it? the chip itself just has sst on the top of it nothing special about it i see blanks on the net that look just like it so im kinda at a loss
Why are you just not running a the correct STOCK ECU?
Since you never ONCE mentioned what car you drive or any specs (which is required in this forum per the rules) about it or why you need a chipped ECU, that's the only advice I can give.
has a short ram cold air a 4-2-1 mani has a ls b18b1 and tranny as far as i can tell its just stock from looking at it aftermarket crank pully gold color has a single plug dizzy 62 mm tb thats about all i can tell ya about the car after looking at it tinkering with it ect
the main reason i want to put a different chip in it is mainly due to its always rough idle when warm at 500 rpm and always missing at an idle cold or hot ive given it a full ignition system overhaul and cleaned the iacv and it feels like someone pulled the e brake at 3k rpm to 4k rpm and then pulls really hard 4 to red line oh and gets about 20 mpg or less with o2 plugged in about 30 mpg unplugged
sorry i was in the middle of typing that post when i saw your new one anyways this is helpful wish i could thank you somehow for this advice as i am still trying to learn
