d16a sputtering
Old Oct 26, 2012 | 11:15 AM
redmondracing's Avatar
Default d16a sputtering
okay 93 civic ex d16a swap z6 IM, 4-2-1 header, and cai. other than that stock.
i need help with the sputtering, it sounds like its misfiring and theres soot all the way up my bumper idk what this could be maybe fuel pressure regulator? im lost, and also new to the honda game ha
any help is very much appreciated!
Old Oct 26, 2012 | 11:22 AM
JuggerNaut-CTR's Avatar
Default Re: d16a sputtering
check timing
plug wires good? In correct firing order?
Old Oct 27, 2012 | 12:05 PM
new ngk plugs and wires, and timing is on exactly and spark plugs go 1-4 starting from timing side of motor to tranny side with firing order of 1342.
Old Oct 27, 2012 | 12:31 PM
Former User's Avatar
You have an OBD0 engine in an OBD1 car. Give details about the swap. For example, what ECU? And what CEL codes?
Old Oct 27, 2012 | 02:45 PM
soon to be chipped p28, and iat, iacv, and map sensor cel's everything else as wiring goes is obd1 and hooks right up besides having to change the connectors for the distributor
Old Oct 27, 2012 | 02:46 PM
also the car does accelerat fast high rpm range and sucks gas all the time i think it has to do with the misfiring
im just stuck and really want to figure it out because im planning on boosting
Old Oct 27, 2012 | 03:42 PM
You need to fix those codes.
If you reset the ECU do all three codes return?
Have you checked for swapped sensor connectors?
Old Oct 27, 2012 | 03:54 PM
i have reset and they all appear and yes theres a sensor at the back of the motor by the oil filter that has no connector, and the air conditioning connector is unplugged other than that everythings there
Old Oct 27, 2012 | 03:56 PM
also i've changed map sensor 3 times all used but different and the cel still comes back also bought brand new iat sensor and code is still on, and the iacv has been swapped from the junk yard.
Old Oct 31, 2012 | 12:14 PM
need some suggestions! guys
4dr_eg
18
Oct 28, 2013 04:26 PM
Smurf93
Mar 29, 2013 08:28 AM
JDMb18c1HATCH
Jul 3, 2010 07:26 PM
jdmdohcek98
Sep 25, 2006 11:14 AM
Dublocivic
Apr 16, 2004 11:19 AM
