Fuel pump whir not pressure
Old Oct 26, 2012 | 09:04 AM
carlos8's Avatar
Default Fuel pump whir not pressure
hi guys, sometimes my civic not whant to start after turn it off, always after
some use. The car have spark the fuel pump activate but not build pressure. If you let it seat for half hour she start again. It's the fuel pump?
thanks in advance
Old Oct 26, 2012 | 10:29 AM
Turbo-LS's Avatar
Default Re: Fuel pump whir not pressure
If wont hold pressure the regulator could be bad unless pump isnt priming after its hot ?
Old Oct 26, 2012 | 01:07 PM
wantboost's Avatar
Who is Mr Robot?
Is the pump really loud?
Could be a bad pressure regulator, pressure relief on the pump is bad, bad pump or pump wiring.
Is it a stock pump? Also your fuel pump relay could be bad
eg:R
Sep 1, 2011 08:37 AM
trustdestruction
Jun 28, 2010 10:45 AM
trustdestruction
dome
Sep 25, 2007 02:50 PM
ill phil
Apr 23, 2003 11:58 PM
