340lph fuel pump
Old Aug 29, 2011 | 01:01 PM
eg:R's Avatar
Default 340lph fuel pump
Anyone try any of the 340lph fuel pump that does work as what they say? I'm planning to get one but I heard a lot of goods and bads about the pump. I've also notice there are a lot of the 340 pump out there. Let me Which one is tested and proven... Thanks
Old Aug 29, 2011 | 02:23 PM
Gunmetal_B20_Hatch's Avatar
Default Re: 340lph fuel pump
Im pretty sure the Aeromotive pump is well-proven... I just installed one in my hatch yesterday, but havent had time to go and drive it.
Very good fuel pump comparison that ultimately swayed me to get a Aeromotive 340lph: http://realstreetperformance.com/sto...on-test-5.html
Old Aug 30, 2011 | 02:02 PM
eg:R's Avatar
I didn't know on boost application that a lower base pressure like 40psi will be better Due to boost pressure. I have my 255 with base pressure of 55psi. I must out out working the pump.
Old Aug 30, 2011 | 09:02 PM
sweetfwdthunder's Avatar
That just depends on the rest of your setup and the goals you're trying to achieve. From what I've seen, all of those new pumps generally flow around the same numbers..seems more like its down to personal preference. The dw pump comes with a 3yr warranty, I think the aeromotive comes with a 1yr and not sure about the new full blown fb340. Im sure you can trust the performance of any one of them though
Old Aug 30, 2011 | 09:12 PM
CO_RaceFab's Avatar
We are replacing walbros left and right with these they are great for street cars
Old Aug 30, 2011 | 10:00 PM
eg:R's Avatar
Which one are your guys using?
Old Aug 31, 2011 | 01:10 AM
CO_RaceFab's Avatar
The aeromotive 340lph they free up some room for more power compared to the walbro 255lph
Old Aug 31, 2011 | 09:58 AM
rabbid sir's Avatar
Just like I posted in another thread, the aeromotive I think is the best. I made 614 on e85 with 1 aeromotive intank pump and dw1300's. 10:1 81.5mm b16 stock sleeves t3 s366 24lbs
Old Aug 31, 2011 | 10:47 AM
sp00led's Avatar
^ Interesting. I wonder if I could make 500-550whp on my GT30R on E85 using ID1000s/aeromotive intake pump. This would keep me from having to buy the proven and more expensive bosch inline 044 pump.
Old Aug 31, 2011 | 12:02 PM
eg:R's Avatar
What base pressure is best? Is it ok to tune over 100% on the injector duty cycle?
Old Aug 31, 2011 | 05:30 PM
rabbid sir's Avatar
We made 568 on e85 using the 255/044 combo with ID1000's. Duty cycle was 95%. 10:1 1.8 w/ a 6262
Its not possible to go past 100%. Try to keep the duty cycle below 90. My 1300's were maxed (100%) to make 614. So now I have 2000's. As for base pressure on the 568hp motor, it was pretty high. Not gonna say how high for fear of being roasted. lol! My car the base pressure was 60. I'm also using a fuelab regulator if anyone wanted to know.
Old Aug 31, 2011 | 05:52 PM
It would probably be very difficult, in order to get the 1000's to flow enough you'd need to crank the base pressure up quite a bit. The aeromotive wont flow as much at higher pressures I believe the reason why It worked out for rabbid was because he could run lower base pressure with bigger injectors, which is where there is a more optimal flow for the aeromotive.
Old Aug 31, 2011 | 09:26 PM
eg:R's Avatar
Did you notice fuel pressure increase when installing the 340 pump? How much more over the 255 pump.
Old Sep 1, 2011 | 12:09 AM
CO_RaceFab's Avatar
The pressure in a customers accord went up noticably I don't remeber exactly how much but we had to back it down a bit.... if you have id1000s you can use a base pressure of 75-80 psi depending what you are going to make boost wise 120 psi and the pumps fall off pretty hard so 75psi base with 35psi manifold pressure and your at 110psi in the fuel rail which is perfect... that's good for some decent power on gas.
Old Sep 1, 2011 | 07:06 AM
rabbid sir's Avatar
Just a small reminder if yall didnt know. To get the most out your pumps, wire them to a relay from the battery. I was barely getting 12.5 volts to my stock plug. Now I get a clean 14.2 with the car idling.
Old Sep 1, 2011 | 08:37 AM
You SHOULD not need to re-adjust your FPR unless your return line is way too small or restricted. I didnt have to change mine when I installed mine last week(up from a Walbro). Base pressure = 60psi. OEM regulator w/ B&M adjustable spring, OEM feed and return lines.
dome
Sep 25, 2007 02:50 PM
Todapwr
May 12, 2004 07:51 PM
Andrew 825SM
Nov 17, 2002 01:42 AM
TurbothisLS
Aug 28, 2002 07:57 AM
Tuan
May 23, 2002 05:45 PM
