plz some help
Just installed new Bosch hid xenon on my 2007 accord with low beam lamps, The problem is when i turn the low beam on, The fuses of low beam blown up.
i checked up the hid kid with another car and its working fine but on my accord when i turn the headlights on the low beam fuses just damage.i changed the fuses but the problem still exist.
note:when i remove the new HID and return the factory one the problem is gone.
hopefully you didnt pay much for that kit.. bosch doesnt make kits unless they are for oem setups like d1/d2/d3/d4 bulbs.. are you running a relay harness? only reason, i see the fusing popping is because something is shorting out..
crazyfast
Nov 8, 2008 11:15 AM
Devine
Nov 28, 2005 02:31 PM
