Headlights out...
I turned on my car today and found that both of my headlights went out. Does anyone know what I should do to fix this? I find that its odd they both went out.. I just changed the head lights a few months ago..
Might just be the fuse or relay. Use this link to identify them. https://honda-tech.com/forums/showthread.php?t=2465423
If that's not it, it may be the switch itself.
Is it just the low beams that aren't working? Have you tried the high beams?
What year is your car? Does the high beam and everything else work except for low beam? My brothers 2001 civic, both light went out, everything but the low beam works. It was a recall from honda.
Here is a FAQ on honda-tech for the recall:
https://honda-tech.com/forums/honda-civic-2001-2005-78/faq-low-beam-headlights-dont-work-but-high-beams-parking-lights-do-whats-wrong-1974402/
My car is a 2005 civic, it's just the low beam that is out.. High beam works as well as the yellow lights. I tried the relays (switching with another one) and that didnt get it to work. Where is the switch? Thanks
Have you tested the harness connectors at the (low beam) bulbs to see if you're getting power to them? I can send you a diagram if that'll help you.
