Cluster in my 99 civic.
Old Oct 24, 2012 | 11:40 AM
Kevin_Ceee's Avatar
Default Cluster in my 99 civic.
The cluster light in my civic won't work anymore yet the indicator lights still do. It worked before. I changed the bulb for my cluster and I also changed the fuse.. I dont know what the problem is.. anyone help?
Old Oct 24, 2012 | 10:52 PM
Bwek951's Avatar
Default Re: Cluster in my 99 civic.
Did you convert to leds? Try flipping the bulbs 180 degrees. Sometimes there just not in there incorrectly and won't light it up. What bulbs did you use to replace?
Old Oct 24, 2012 | 11:05 PM
jdmadam's Avatar
Your dimmer switch has probably gone bad.
Old Oct 25, 2012 | 05:58 AM
Former User's Avatar
Unplug the dimmer switch and then jump the red wire terminal to the black wire terminal in the connector. Do the cluster lights now work?
Old Oct 25, 2012 | 08:48 AM
skylerreniger's Avatar
it is prolly your dimmer switch. take out the switch and run a test light on the wire to the switch. if you are getting power to the switch then it is prolly the switch. to test and make sure it is not the bulbs like they said run a jumper wire and see if they come on for a sec. if you dont have power to your switch tho than it may be a fuse.
19da90
10
Feb 12, 2013 05:29 PM
eghatch909
Apr 9, 2010 05:28 PM
xxjasonxx
Nov 20, 2008 06:08 PM
memorybox
Sep 11, 2006 06:42 AM
thegod
Jul 7, 2006 11:18 AM
