HELP!! Posible Vaccumm Leak! :S
Old Oct 23, 2012 | 08:25 PM
civicEX1995's Avatar
Default HELP!! Posible Vaccumm Leak! :S
hello
I've been feeling rare symptoms in my Honda Civic 95 coupe D15b Vtec as having a vaccun leaks
symptoms are
Rough Engine Idle
Engine Hesitation
Imprecise Transmission Shifting
Poor Acceleration
symtoms are described in this link
it said those symtomps are caused by a vaccun leak.. i feel those in my car..
but i cant find the leak.. can this symtomps really mean a vaccun leak and if is can u tech me how can i find the vaccun leak.
my cars Has no CEL
Thanks
Old Oct 24, 2012 | 05:22 PM
salaamq's Avatar
Default Re: HELP!! Posible Vaccumm Leak! :S
VERY CAREFULLY while the engine is running spray around with some carb cleaner/quick start. If you have a leak it should get sucked in and change idle.
Keep in mind that if you light your car on fire I'm not responsible... I would have a fire extinguisher close by.
Look at this for more info.
Old Oct 25, 2012 | 08:13 PM
http://www.youtube.com/watch?v=9CPqbaSgcok
Thx, i have spend like an hour yesterday doing this.. i cant find it... i hav sprayed carb cleaner near of PCV, fuel Injectors, Break check valve and no results
Old Oct 25, 2012 | 08:41 PM
dirty19's Avatar
Ridin Dirty in Cali
Eric the car guy! good tutorials for those who just dont know...
Old Oct 26, 2012 | 07:41 AM
salaamq's Avatar
Hmmmmm... How long has the car been doing this?
Could it be ignition timing? Not sure on that someone confirm that
Maybe a misfire, or a lean/rich condition?
Some of those vacuum leaks are hard to find though, I wouldn't completely rule it out.
Old Oct 26, 2012 | 07:58 AM
Ayee_drian's Avatar
There was a vacuum leak on my civic, i spent hours looking for it. I just took it to my friends shop and one of the guys there had a weird stethoscope thingy and found the leak in a few minutes. It was next to the throttle body. My car was idling funny as well. BTW i have a 98 civic. just my two cents.
Old Oct 26, 2012 | 05:19 PM
salaamq's Avatar
Maybe these will help? Never had idle issues.
Old Oct 26, 2012 | 09:03 PM
Former User's Avatar
Doesn't sound like a vacuum leak at all to me. My guess is that the engine just needs a tune up.
Old Oct 27, 2012 | 04:27 PM
Today some rare things happen.. my car was checked by an honda electricist and he found my tps plug has 2 pin swaped the green white wire and the yellow white wire, he swap the wires together and all the problems seems to be fixed... the only prob i still have is rough idle but this only happen when the car is on operating temperature, when cold idle i just fine.. what can i check fot rought idle only when car is on operating temperature
Old Oct 30, 2012 | 12:11 PM
strategy400's Avatar
Check your compression if that's good do a major tuneup. I would suspect a vacuum leak if any work had recently been done to the intake.
Old Oct 30, 2012 | 03:09 PM
salaamq's Avatar
Did you spray just those? Spray everywhere where a leak could come from. Still try not to burn it though. That carb cleaner is pretty nasty stuff when fire comes in to play .
ricardoseifert
Dec 3, 2013 10:07 AM
nicklp60452
Jul 14, 2008 02:53 AM
LilCivic04
Sep 9, 2005 11:28 PM
PiYoImuT
Sep 7, 2001 09:08 AM
