Fuel Pump upgrade time
I have an Aeromotive Pro Pump(biggest available aeromotive) and im running e85. Im currently on the edge of running out of fuel. Im running 4 id2000's and want to make the best use of just the 4 to my abilities. I ran 160mph this past weekend whatever that equates to in HP is getting close to maxing out running 12.0-12.3 afr's
What would be a good upgrade without getting crazy?
was looking at the weldon 2035A, dont know if i can swing the 2345 pump or not, to early to say.
Tickled the idea of the dual bosch, but i think the 2035A flows more than that.
Looking for some of you guys who are running the shizz.
what base pressure are you starting with and how much boost pressure are you running? What about a magnafuel efi750 pump. there rated to 2000+hp on gas and can run pressures up to 120psi and are more afforable than the weldon units
im up to changes, typically i run about 45 psi with the lines connected. running out of fuel around 35-36 psi
Magnafuel pumps look great but some FLOW DATA on their website would help speed up making educated choices that are informed.
if you need any info call magnafuel
I think this thread I started will help you out a bit. I was in a similar boat as you. I went with the Magnafuel 4303 because it will support just about all I'll ever throw at it.
https://honda-tech.com/forums/drag-racing-36/fuel-pump-questions-magnafuel-4303-a-3082525/
I have a little information about magnaflow, we're doing a build right now and when we talked to them about the same pump, they said the MP4303 would be good for 1100fwhp on E98 with high combined fuel pressure. I have some more data as well in one of my emails , I just need to dig threw that. The customer opted for a magnaflow because of the price and its a little bit easier to use on a street car. We have them in stock as well so if you're looking to purchase one, contact us.
Import_2
Oct 23, 2008 08:35 PM
Smoothy
Oct 6, 2001 06:48 AM
