locked motor?
Old Oct 22, 2012 | 02:54 PM
fumes510's Avatar
Default locked motor?
So my friend and i were going to get some food the other day and we were in his car and all of a sudden his overflow tank falls out, then when he pressed on the gas to pass someone there was no response, the car was stuck at 65mph and it slowly started going down in speed. When we came to a stop light the car just died and he tried turning it on but it wouldnt turnover. The fuel pump wouldnt prime either, and when we check to see if any fuel was coming out there was non. My guess is the fuel pump went out. But i was wondering if the motor might have hydro-locked? The motor is a d16z6 head with a d15b block. Its running on 7lbs of boost. And it has stock internals.
Old Oct 22, 2012 | 04:44 PM
hybridmiklo's Avatar
Default Re: locked motor?
The motor hydro locking will have nothing to do with the fuel not priming. Does the engine crank?
Old Oct 22, 2012 | 07:00 PM
fumes510's Avatar
no, the engine does not crank.
Old Oct 24, 2012 | 05:39 PM
fumes510's Avatar
bump
Old Oct 25, 2012 | 08:10 PM
fcm's Avatar
fcm
Old Fart
The only way the engine would "hydro-lock" would be if you drove through a puddle deep enough to submerge the complete air intake.
Beleave me, when an engine hydro-locks, you know it, it is one ugly sound.
Also as mentioned, the fuel pump not priming has absolutly nothing to do with an engine hydro-locking.
Questions...
MM&Y of car?
Do you have any power at all, head lights, horn, blower motor, wipers.
When you try and crank the engine to start it, is there any sound at all, even a "click" from the starter solenoid?
Have you tried a bypass jump?
https://honda-tech.com/forums/showth...cm+bypass+jump 94
greenman420
Dec 19, 2010 07:50 AM
YangFlavor
May 17, 2010 11:40 PM
dudeomega2000
Jul 13, 2009 08:15 PM
TylerC161
Dec 13, 2006 08:58 AM
brockscivic
Jul 23, 2004 04:56 AM
