all motor "gsr" question
Old Oct 22, 2012 | 02:18 PM
flatblackfury91's Avatar
Default all motor "gsr" question
guys i'm planning on building a motor in the near future. what you think of my setup? gsr block and rods, ls crank, and a b16 head with pr3 pistons. just wonderin if anyone has done this and i'd like to see the link. its supposed to be around 12.45:1 compression.
Old Oct 22, 2012 | 02:23 PM
doood's Avatar
been there done that
Default Re: all motor "gsr" question
dont mismatch the crank and rods. you want to use an ls crank, use ls rods.
Old Oct 23, 2012 | 11:11 AM
and why is this?
Old Oct 23, 2012 | 11:23 AM
doood's Avatar
They are different lengths
Old Oct 23, 2012 | 11:50 AM
thats the point. its kinda like ls-v without the ls block. no positive deck height. just seeing if anyone had done this.
Old Oct 23, 2012 | 06:50 PM
angryhillbilly's Avatar
you cannot use gsr rods and a ls crank in a gsr block. you will need shot peen'd and ARP rob bolts in LS rods or aftermarket LS rods. there are better ways to increase compression.
I have a "GSR mini stroker" build myself. with carillo ls rods and CP pistons.
great build.
Old Oct 23, 2012 | 07:47 PM
ej1_civic's Avatar
Do gsr rods on a ls crank and tell us the results if it was a good idea!
Old Oct 27, 2012 | 06:13 AM
i just want a straight foward answer. why cant it be done? piston kills combustion chamber?
Old Oct 27, 2012 | 08:38 AM
Thought I was clear and straight forward with my first post.*b20 crank and b18c rods will not work. The journal width of the crank and the big end of the rods do not match. Let's say you will have a oiling issue
carlossolorzano
May 27, 2012 01:12 AM
1991islsv
Nov 21, 2008 07:25 PM
Mfoehrkolb
Nov 21, 2007 05:37 PM
TurboEH2
Apr 2, 2005 11:15 AM
B18C-EJ1
Jan 19, 2002 11:45 PM
