Want to Buy Want to Trade/Want to Buy
WTB 84MM Low Comp Forged Pistons!
Old Oct 21, 2012 | 08:38 AM
bvillarreal's Avatar
Icon3 WTB 84MM Low Comp Forged Pistons!
Looking for b20 forged low comp pistons with rings/wrist pins. Best way to get a hold of me is by text 386-675-2078
Old Oct 22, 2012 | 10:19 AM
eK24monster's Avatar
Default Re: WTB 84MM Low Comp Forged Pistons!
Hello,
What are you doing for connecting rods? Would you consider 84.5mm?
It would be better to start with a fresh bore with a new set of forged pistons so you can control the cylinder wall clearance and get the best ring seal.
I have a set or CP's for sale in this thread... check them out! http://hondamarketplace.com/showthre...2#post48016502
My friend was building a 95mm x 84.5mm boosted stroker motor using a DART head and block. You cant use the rods but you can take advantage of a SICK deal on the pistons... if you are open to possibly running a custom rod. The rod would need to be a little longer (139.45mm to get a 0 deck) then a stock rod, which in itself would be a nice addition. The longer rod would improve the rod to stroke ratio from a 1.54:1 to a 1.57:1. The compression ratio would be 9.4:1 with a PR3 head or 9.5:1 with a P72 head using a stock gasket.
Old Oct 24, 2012 | 09:02 PM
Charlie Moua's Avatar
i have some used 84.5mm wiseco 9.1cr pistons.
ElswickB22
Aug 6, 2013 08:44 PM
SL0-hatch
Northeast (Sales)
Sep 18, 2008 06:00 AM
SL0-hatch
Sep 18, 2008 05:59 AM
JohnnieChimpo
Apr 15, 2008 11:34 AM
del_slow420
Jul 27, 2006 08:58 AM
