Broken Turbo or Still Good? please help
Old Oct 20, 2012 | 03:11 PM
E-PiLLs's Avatar
Default Broken Turbo or Still Good? please help
sorry just another noob, tried looking for pictures of broken turbo but all i come across is turbo with damage blades and this turbo looks like this. I am not sure if it is still good or not, but please help.
*note, blades are not damaged anywhere
It does spin but no very long, maybe 2-3 seconds spinning freely only. I heard that spinning freely is good but idk for how long it should spin.
Old Oct 20, 2012 | 03:12 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Broken Turbo or Still Good? please help
Get it rebuilt.
Old Oct 20, 2012 | 04:39 PM
E-PiLLs's Avatar
how long will it last if i don't rebuild it?
Old Oct 20, 2012 | 04:59 PM
doood's Avatar
been there done that
2 minutes
eljoker's Avatar
Well, would you rather spend a few hundred now to rebuild it or chance spending a lot more for the damage you have to fix when it goes ka-boom?
Old Oct 20, 2012 | 11:07 PM
E-PiLLs's Avatar
Ok I am set to buy a rebuild kit but...
Even if I buy a rebuild kit it won't fix the part that I pointed out in the picture..
or is that part that I pointed out fine and won't effect anything?
Old Oct 21, 2012 | 03:28 AM
rice a roni's Avatar
:/ pics kind of suck but it looks like it was ground off. Thats what they do when you get it balanced.
Old Oct 21, 2012 | 08:02 AM
E-PiLLs's Avatar
It looks like it was cut finely by something, but just on one side too.
I guess after a rebuild kit I'm set to go, btw..
This will be going in my ls/v
Old Oct 21, 2012 | 10:19 AM
Mine is ground just on one side. Its called balancing, usually one side weighs more so it has to be ground on the heavier side :/ weirdo
Old Oct 21, 2012 | 10:29 AM
rich7777's Avatar
Old Oct 21, 2012 | 11:12 AM
SiRCiviC94's Avatar
id try it out. people like wasting money sometimes for no reason. have a shop check it out too
Old Oct 21, 2012 | 12:57 PM
vwbased's Avatar
have a nice day
Old Oct 21, 2012 | 08:55 PM
DaveP1's Avatar
If when the compressor housing is on and you cant make it touch the house when pushing on the shaft then run it journal bearing turbo's need to have some play so if its not hitting the housing and no end to end play then run it don't be scared
Old Oct 22, 2012 | 08:29 AM
E-PiLLs's Avatar
ok, so what i got from this is that.
it will only spin for 2-3 sec like what i have? it's not rough, pretty smooth too.
and it doesn't have a lot of shaft play.
so i'm good to go on this turbo then
oh and those marks was just to balance the turbo
BodyKits NW
Jul 12, 2005 04:03 PM
hcivic99
Feb 1, 2005 06:37 PM
ff9zidane
May 10, 2004 04:53 PM
TurBoXBirD16
May 8, 2003 08:31 PM
