emissions test delaware
Old Oct 18, 2012 | 05:08 AM
Dohc eg coupe's Avatar
Icon6 emissions test delaware
hi i have a turbo honda i was just wondering how i can pass the emmissions test in delaware by keeping the turbo on the car i was running 20 psi but i put it down to 5 psi and im about to put a cat on it but do i need to do anything else to pass oh and my friend mixed alcohol in his gas with his turbo gsr and it passed is that bad to do cuz im bout to just do that
Old Oct 19, 2012 | 08:38 AM
cvcrcr99's Avatar
Default Re: emissions test delaware
You could always put a stock tune on the car, and unhook a intercooler pipe so boost doesn't make it to the motor.
Old Oct 19, 2012 | 08:42 AM
Muckman's Avatar
Moderator in Chief
Delaware = actual emission test or OBD2 scan?
Old Oct 19, 2012 | 08:59 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
More info needed. What type f emissions test, what year car, what motor, running what ecu....etc?
Old Oct 19, 2012 | 09:31 AM
wantboost's Avatar
Who is Mr Robot?
turning down the boost won't matter.... you won't get into boost during an emissions dyno session
Old Oct 19, 2012 | 10:32 AM
Bseriescivic5's Avatar
I may be the one you are refferring to.... Its tough in delaware, if the car is OBD2 you are basically fucked... must convert back to stock and run stock ECU. If you are OBD1 you have some options.
As one who has personally done this, it took me about 15-20 times to finally get through.. You will need to do the following:
1. You need a CAT, no way around this from my experience
2. ID1000s seem to have a better chance to get through since the fueling is more precisely controled.... I knew a guy that had the older style PTE injectors and he pulled an injector clip and that improved his emissions, but you cant have a engine that sounds like a subaru either so you have to be careful with this technique
3. Have a good tune.... even with my Jeff Evans tune, car was still richer than most N/A hondas so you may want to adjust the tune for the inspection and then return to your old tuned map once you pass
4. Alcohol...... Ethanol is your friend and used just in this scenerio and then burn off the rest of the fuel should cause little issue with the car. my cocktail was drain fuel down past 1/4 tank and add in 1-2 gallons of 100% ethanol.... I worked at a lab so I sourced it easilly... if not, try using E85 and see if that lowers your #'s enough to get through.
DO NOT USE METHANOL.... as this increased my #'s for some reason... im not sure why exactly... but you want to use ethanol and no other isoform of alchol...... IE isopropanol does not work well either.
Hope this helps.... im local as well so feel free to get in contact if you are still having issues.
Old Oct 19, 2012 | 04:12 PM
wantboost's Avatar
Who is Mr Robot?
You can pull the wastegate spring out, put stock injectors and ecu in and skip removing all the turbo stuff
Old Oct 22, 2012 | 06:08 AM
im obd1 so im gonna try what u said bseriescivic5 or just take the turbo off and put stock header back on because i havnt tuned it yet anyway but thanks for the help
Old Oct 22, 2012 | 07:01 AM
spoolinlude's Avatar
I live under a rock
<--DE guy.
I passed with no cat (had a heat shield so it looked like one), with my Evan's pump gas tune, no strange gas tricks, 100% pump fuel. No charcol system, and coil on plug. Was hilarious watching them try to hookup the little RPM meter to my coil wires.
Prelude is OBDI..... passed with flying colors on emissions. I think it depends on WHO you actually get that day (at DMV), some people are more **** than others, the dude that worked on my inspection just put "M/F" in a bunch of the columns, basically stating that his equipment malfunctioned while trying to run my car.
"Boost" has nothing to do with the equation. You could have it set at 100psi or 1psi, it doesn't make any difference, your car doesn't go into boost sitting still. Need a load on the engine.
Old Oct 22, 2012 | 09:08 AM
Originally Posted by spoolinlude
<--DE guy.
Interesting..... Maybe your ignition system has something to do with why you passed so easilly (coils more efficient? IDK), but I know I had a hell of a time getting through, started to know guys down there by name I had been through so many times. At the end of the day I needed a cat, ID1000s, good tune, and a bit of ethanol to get her to pass. In any event good to see at least a few guys getting through on the first shot.
portaman03
Honda Civic (2001 - 2005)
10
Apr 30, 2007 08:08 PM
Komsomol
Feb 26, 2006 06:54 AM
plusONE jboy
Apr 27, 2005 06:07 AM
MulletManRockStar
Oct 13, 2004 12:44 PM
