turbo a rebuilt engine?
Old Oct 20, 2012 | 11:15 AM
mondies_8's Avatar
Default turbo a rebuilt engine?
i have a integra 94, b18c1, i just got the engine rebuild and it has 400 miles. im trying to decide on wether i should turbo it, like 5-8 boost.
im starting to do research on it, but i want to know just the pros and cons on it. And what other people think about turbo.
any help is greatly appreciated. please no negative posts.
Old Oct 21, 2012 | 01:20 PM
hapamang1503's Avatar
Default Re: turbo a rebuilt engine?
when you say you had it rebuild what all did you have done?
Old Oct 21, 2012 | 04:34 PM
fcm's Avatar
fcm
Old Fart
Same question, kind of, was it rebuilt for turbo? 94
Old Oct 21, 2012 | 10:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Even a stock rebuild would be fine with a little boost. The key for the motor to run good and long is have it tuned by a good tuner and the motor will run great. Break it in or have it broke in on the dyno and tune it!
Old Oct 22, 2012 | 08:43 PM
mondies_8's Avatar
new pistons, rings, seals, gaskets,not sure what else
Old Oct 22, 2012 | 08:44 PM
mondies_8's Avatar
what do you mean by a good tune??
i have 457 miles on the engine right now
Old Oct 23, 2012 | 12:19 AM
mondies_8's Avatar
another thing is, my car is salvage. so is it even worth it adding the turbo?
Old Oct 23, 2012 | 01:35 PM
mondies_8's Avatar
bump
Old Oct 23, 2012 | 01:56 PM
Schister66's Avatar
Man U FTW
There's no reason not to turbo it IMO. I'm actually in the process of rebuilding a bone stock GSR (B18c1) for a friend and he intends to boost it. A stock B series with a proper tune and appropriate fuel is safe in the mid 300whp range...so stop setting goals in terms of PSI. As far as you're concerned, boost pressure is only relevant when choosing a MAP sensor...and I'll make that easy for you, get a GM 3bar map sensor if/when you boost.
Read the Forced Induction FAQ and start to wrap your mind around what exactly is involved with this project. Members here will help you on your way, but they wont spoon feed you everything
w3aselll
May 20, 2010 05:28 PM
2gteg93
Feb 9, 2005 12:52 PM
JoeD427
Dec 17, 2004 05:08 PM
yusoslo
Mar 23, 2004 06:26 AM
Briman2021
Oct 28, 2003 08:34 AM
