NEED PROFESSIONAL AEM TUNER - READY TO PAY
Old Oct 18, 2012 | 10:31 AM
honda_12V's Avatar
Default NEED PROFESSIONAL AEM TUNER - READY TO PAY
Hello,
I am looking for a PROFESSIONAL TO HELP ME TUNE MY AEM SERIES 2 BOX.
Unfortunately I am not in the USA, I am looking for someone who can make a base map - specially for starting the car only. I can tune the car for running, its just that am stuck with the start.
Car in question is a honda accord engine H22a Type S (modification are street clutch and light flywheel, 70mm tb.)
I am looking for a tuner who can make and mail me a base map to start the car, and give me on-line support.
Like i said earlier am ready to pay reasonable price for the service am looking for.
Please PM me.
Regards
Old Oct 18, 2012 | 10:58 AM
accorse07's Avatar
Default Re: NEED PROFESSIONAL AEM TUNER - READY TO PAY
When you download AEM Tuner for your Series II box, there are a multitude of base maps that come with the software that you can use. These maps are there for you to load and with basic set-up you should be able to start the car.
If you can tune the car for running, simply reading the instructions that came with your EMS will enable you to load a base map and get the car started.
Or you can pay someone on here to send you something you already have and can learn for yourself
Old Oct 18, 2012 | 08:23 PM
honda_12V's Avatar
Hello,
Initially I tried to start my car on the base map given my AEM for H22 Del sol.
The would not start at all. It would just keep cranking.
Start Sync is on, i check the throttle, checked the TPS value etc. followed all instructions given by AEM. Even posted everything on AEM forum but no strong replies.
I get the car started in 4-5 cranks. Last night trying to make it better I blew my second starter and I guess that is just a sign i need professional help.
Would you know anyone?
Regards
Old Oct 19, 2012 | 05:53 AM
xenocron's Avatar
Originally Posted by honda_12V
Hello,
Regards
If you are blowing starters, then two things.
#1 - Battery voltage LOW when cranking. Hook up the car to a battery charger when cranking and first trying to get a car started always.
#2, double check your timing. Pull all plugs, hook the car up to a battery charger, hook up a timing light and set base timing BEFORE trying to actually start the car. Get it close or you may have serious issues with "back cranking" if your timing is way off.
http://www.xenocron.com/xenocron-bas...rtp-p-573.html
I dont think you do, but if you REALLY need a basemap to get started after trying those two suggestions, I can certainly try to help.
Old Oct 19, 2012 | 06:01 AM
honda_12V's Avatar
Sir,
Initaially the battery voltage was faulty, i moved to a small truck battery.
The starter now moves faster than before but she still wont start up in 4-5 cranks.
It cranks and cranks then the starter hits a wall and flat lines, it jerks the car.
Please advice.
Regards
mycarslow
Engine Management and Tuning
Mar 25, 2015 08:57 AM
crxmanror
May 10, 2013 02:36 PM
1FASTHF
Nov 3, 2012 07:06 PM
honda_12V
Oct 19, 2012 06:31 AM
