What parts will directly fit for sway bar?
Old Oct 18, 2012 | 06:09 AM
Emeraldbomber's Avatar
Default What parts will directly fit for sway bar?
I just got a pretty good deal on a sway bar and bushings but I still need endlinks, d brackets and the stabilizer bracket that bolts into the sub-frame.
Now, ive done my research but im still kind of stuck. I have a 94 civic ex (ej1)
Now I know I need endlinks off of a 99 civic si.
But what about the d bracket and the stabilizer bracket? Can I get those off of a GSR or 99 civic?
I found this but im not quite sure if they are the same
http://www.acuraoemparts.com/delray/...ty41=1&qty42=1
Old Oct 18, 2012 | 06:15 AM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: What parts will directly fit for sway bar?
What swaybar? You didnt mention what kind you got?
If its a stock swaybar then yes part number 4 is what you need
Old Oct 18, 2012 | 09:23 AM
Sorry, 17mm Eibach bar
Old Oct 18, 2012 | 06:02 PM
Can I use part numbers 30 and 28 from the si?
http://www.hondapartscheap.com/parts...rear-lower-arm
Old Oct 18, 2012 | 07:30 PM
bump
Old Oct 18, 2012 | 07:56 PM
dirty19's Avatar
Ridin Dirty in Cali
I really couldnt tell you.
Old Oct 18, 2012 | 08:12 PM
egsleepercivic's Avatar
what is the sway bar off of ? is it oem or aftermarket ?
then we can answer your question
Old Oct 18, 2012 | 08:13 PM
nevermind missed that it was eibach, take a pic I don't think they use the stock mounts unless maybe it was for a teg with a stock sway bar
Old Oct 19, 2012 | 05:41 AM
Im at school currently, but I dont have any mounts or brackets due do the ej1 style not coming with a rear swaybar. I have function 7 lca's and I need endlinks the mounting bracket that bolts into the subframe and d brackets. I just need to know what I can get them off of.
Old Oct 19, 2012 | 10:52 AM
94-01 teg brackets and endlinks work with an OEM sway bar, I have them on mine, not sure it they will work with the eibach bar
Old Oct 19, 2012 | 12:25 PM
Okay thank you sir. The gsr bar is 14mm correct?
Old Oct 19, 2012 | 05:07 PM
yes
Old Oct 19, 2012 | 05:11 PM
here is a pic of the gsr sway on a 93 hatch with oem mounting brackets and hardware as well as 94-01 teg rear lca
https://honda-tech.com/forums/showpo...40&postcount=8
Old Oct 19, 2012 | 05:23 PM
mayfly's Avatar
i do believe that you will need end links to work with the fucntion 7's(aka function 7 endlinks), and they should be adaptable to most sway bars. someone correct me if im wrong
Old Oct 19, 2012 | 08:19 PM
I have also heard that. I think it only works in 1 hole so you cant adjust them to stiff or soft. Does function 7 sell endlinks that aren't spherical? I have harsh winters here in iowa.
Old Oct 19, 2012 | 08:46 PM
98civdx's Avatar
Master Detailer
Nope. Can you even use EK endlinks on a EG? I would think the geometry is all wrong.
But if that's what Eibach wants you to use, check out Hardrace endlinks.
Old Oct 19, 2012 | 09:20 PM
Honestly im not rightly sure even what endlinks I could use for it. Originally I was just going to use oem 99 si endlinks but I totally forgot about the adjustability.
Ive been trolling around the forums and ive seen your name quite a bit in suspension threads. Could a man of your knowledge help me out?
Old Oct 19, 2012 | 09:44 PM
98civdx's Avatar
Master Detailer
Well the normal endlinks aren't adjustable, they are fixed. The adjustable ones are the ones like Function7 sells.
I have blox adjustable endlinks and I hate them. Very noisy after about a year of use. They really don't last long on the streets, at least mine didn't. However that could simply beucase they Blox.
I'll see what I can find, but I'm not too familar with EG's. I would start with calling Eibach and asking them which endlink they reccomend using.
EDIT- Did you see this? It appears that he used a OEM EG/DC endlink.
http://importnut.net/swaybar.htm
Old Oct 19, 2012 | 09:54 PM
I've been clearly steered away from blox many times. I live on really rough roads here, like a ton of potholes, broken up pieces of road and uneven bits of road. Function 7 is usually pretty good about strength but what about blox steers many away? overall structure? not durable?
Old Oct 19, 2012 | 10:00 PM
98civdx's Avatar
Master Detailer
function7 is great, the spherical bearing endlinks just aren't known to last. On rough roads you will hear them. Poping, clicks, clunks, etc. Mine sound like the car is going to fall apart.
Although I haven't used function7 endlinks. I'm just speaking to my experience with spherical bearings. I would reccomend agasin't them.
I will say this. I have considered buying Function7 endlinks to replace the blox endlinks, but I'm willing to deal with the noises they make. Some aren't.
Old Oct 19, 2012 | 10:11 PM
I did look at the site of the swaybar install and I know I can use gsr endlinks but apparently the bolt isnt long enough to go through the beefy f7 lca and thread on.
Old Oct 19, 2012 | 10:16 PM
98civdx's Avatar
Master Detailer
ohh. I didn't know you had Function7 LCA's. In that case, I think you are stuck with using after market endlinks.
Old Oct 19, 2012 | 10:23 PM
Damnmnnnnnn....... thanks for the help though man! I love learning this stuff at such a young age
Old Oct 19, 2012 | 10:33 PM
98civdx's Avatar
Master Detailer
Young is the best time to start.
Old Oct 19, 2012 | 10:48 PM
Agreed, only 16 and I get to teach my dad things!
Billybobby
May 20, 2016 02:19 PM
mugen si
May 3, 2009 06:29 PM
CP9A6M
Feb 19, 2006 10:49 PM
pistolpete
Feb 10, 2006 07:09 PM
