Suspension & Brakes Theory, alignment, spring rates....
ej2 suspension upgrade
Old Oct 12, 2012 | 06:26 AM
fabioso's Avatar
Default ej2 suspension upgrade
Will a sway bar from integra or ex fit my car, or do I need the control control arms too? What about rear?
Old Oct 14, 2012 | 07:05 AM
fabioso's Avatar
Default Re: ej2 suspension upgrade
bump
Old Oct 14, 2012 | 08:54 AM
grumblemarc's Avatar
The Grumpiest
I'm sure this question has been asked before. Let me know if you need me to track it down for you.
Old Oct 14, 2012 | 01:00 PM
egsleepercivic's Avatar
ej2 = 92-95 dx ?, if so yes, get the swaybar, brackets, bushings, endlinks and rear lca from a 94-01 teg non type r and it will bolt up, I believe the LS was 13mm and the gsr is 14mm
Old Oct 14, 2012 | 02:34 PM
fabioso's Avatar
cool guys thanks, and yes ej2= dx 92-95. So I don't need the lower control arms from whatever car I get the swaybar in the front too? I've been racing this guy that lives around me on the local track and want to help out my civic since it's at a big disadvantage on power. Swaybars, strut brace, and koni yellows should help me out a bit from my stock setup?
Old Oct 14, 2012 | 04:08 PM
lca= lower control arm.
unless the ones you currently have, already have the mounting points for the sway bar endlinks you need them, any 94-01 teg non type r will work
**edit **
re read your post, I don't believe the dx's had a front swaybar stock so you will need the front lca as well if you you want to put one on the front
Old Oct 14, 2012 | 04:12 PM
The Grumpiest
You will have massive oversteer if you have no front swaybar and install a rear one. In case you didn't know.
Old Oct 14, 2012 | 04:25 PM
front and rear lca
Old Oct 14, 2012 | 06:32 PM
98civdx's Avatar
Master Detailer
**edit **
They didn't have a front sway bar.. He will most likely have to swap the front lower control arms or at least the back half.
krkline2gdsm
Suspension & Brakes
Oct 26, 2007 05:25 AM
pliskin679
Suspension & Brakes
Apr 30, 2007 01:10 PM
ep3boy
Jun 14, 2005 07:55 AM
Wrath of VTEC
Jun 16, 2001 12:19 PM
