Need help.....have an extra 14mm bolt left over
I replaced my rear motor mount by removing the intake manifold and then getting to the T-bracket. I thought I was done putting everything back together, when I noticed that I've got an extra 14mm bolt left over. any ideas?
the 14mm bolt including the bolt head is 1.67in long.
And....i <3 having extra bolts that I can use for other activities! haha. But yeah, I don't want to drive the car unless I can figure out where this goes, I mean, if it was a mere 10mm I might feel less worried, but it's kind of a medium duty 14mm bolt.
MM&Y of car would help.
If it is an 01 Integra...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
The only one I see that is close is #28, [14mmx35mm]or [14mmx1.4in.
What is the length of your bolt not including the head? 94
I'll have to look when I get home. Now that I think of it. I think it might could be the bolt on the t-bracket near closer to the block that goes in from the passenger side.....
spidermancivic
Aug 11, 2007 08:17 AM
