PLEASE HELP: B18a / B18b question
Old Oct 17, 2012 | 10:01 AM
AdrenalineAngel's Avatar
Default PLEASE HELP: B18a / B18b question
Please bear with me and im sorry if i posted this in the wrong area, but i wasnt sure where to post it...
So i currently have a B18b long block and a complete swapable B18a...the B18a is obd1 and the B18b is obd2...
here's my question:
Can i transfer all of the accessory parts (intake manifold, headers, starter, alternator, etc.) from the B18a and put them all on the B18b and just use an obd1 harness? What i mean is will it run with no issues? Everything is stamped p75 so i figured it should...but im still not sure. And i was wondering which ecu i should use...i have an obd1 p75 LS ecu and an obd2a p75 LS ecu...but its going into my obd2a EK...
Any help and comments are greatly appreciated! Thanks!
Old Oct 17, 2012 | 04:18 PM
Default Re: PLEASE HELP: B18a / B18b question
bump...almost 100 views and not one single response
Old Oct 31, 2012 | 09:22 PM
dickdragon's Avatar
You got the right idea there! Use the same ecu. If you're currently using obd2 then use that same ecu and wire harness. When you plug everything up, just be sure that all plugs, plug right up.
AdrenalineAngel
Oct 27, 2012 08:25 PM
AdrenalineAngel
Engine Management and Tuning
Oct 17, 2012 11:43 PM
I got a honda
Jan 15, 2006 07:17 PM
kholmes
Aug 28, 2003 06:40 AM
todds94teg
Jun 24, 2002 12:32 PM
