d15b vtec e rev limiter at 5k.
my 95 lx sedan has a d15b vtec e with a chipped p28
will not rev past 5000. just sputters and pops very similar to 2 step launch control.
this happens when im driving or sitting still, my spedometor works, car burns oil.
https://www.youtube.com/watch?v=Txod...e_gdata_player
i believe it is the ecu but what sensor or arrangment should i check? i have looked online for days
thank you so much for taking the time to read my post i hope honda tech can help!
You need to run the correct ECU for the motor. Your motor is cutting out because at 5k, the second vtec solenoid is supposed to open, but even a chipped P28 can't do that.
single vtec selenoid. its not 3 stage it is vtec e. 12 valve first stage standard 16v second stage. no cels. bulb is good. comes on for duration of fuel pump when i turn key.
does anyone know if z6 and vtec e? (z1/d15b) vtec selenoids are the same? i have a z6 head with a vtec selenoid
I'm having the same issue with my 93 and no cel light on, but does come on like normal when I start up, gonna check see if there is a code saved in there by chance
now that i saw the video im sure its the ecu. i had the same thing happen to me. i had a faulty p28. i got a different one and tuned the car and voila. i can rev past 5k and open vtec
I have something similar going on, but no resolution. Bogs terribly after 4500-5k. How about if you ease into the throttle. Will the motor then rev past 5k?
thats strange. i had the same issues as the video and for me it was the ecu and tune. well good luck ill input if i get any other ideas or suggestions
mikej94civex
Dec 12, 2009 02:52 PM
94EG8
Aug 6, 2008 10:11 AM
