Gauges -- What is everyone running for Oil/Fuel/Air-Fuel?
Hello H-T,
Just wondering what type of gauges everyone is using now-a-days. What type, brand, size are you using.
How many are using Neptune, Racepak, etc.
Pros and Cons of both
Thanks in advance!
Thanks in advance!
i may be off, but if you add up the price of a boost gauge, wideband, oil pressure, water temp, shift light, etc....i think with a racepak you come out with a fairly similar price although it does require a bit more work for the speedo and all.
For the people running Neptune, Hondata, ectune, why not just use the tunerview? Cheaper than just about anything else out there and fully customizable to show anything you want any way you want. That's my plan soon
I have 2 AEM serial gauges. Allows me to scroll through almost every sensor I have and set up warning parameters, on both gauges.
And one mechanical oil pressure gauge as a back up
i use my laptop to see them. other then that going down the track i never look at them so to me gauges are pointless. i have a warning light that will go off that is run thru my aem if anything is out of wack. thats really my only gauge lol!
I have all guages feeding into various misc inputs in my AEM for logging and one AEM output warning to a shift light if oil pressure or WOT/AF hit lean threshold. Also have a manual oil pressure guage that I try to glance at sometimes.
main goal should be datalogging and warning when it comes to guages...
gsr98vtec
Feb 1, 2002 09:05 AM
