please help me B16b wont stay running
Old Oct 16, 2012 | 03:53 PM
lovehondas's Avatar
Default please help me B16b wont stay running
Hi everyone. I just completed my swap this morning and when I went to start it, it starts up and then it dies after 1 second. it's a stock b16b motor and trans. The only non factory item I have on the motor is a golden eagle fuel rail and a fuel pressure gauge. When I unplug the iacv plug it idles for about 5-6 seconds then it dies but when the plug is connected it only runs for a second or two. There are no vaccum leaks at all, I'm soo lost please help. Thank you in advance.
Old Oct 16, 2012 | 06:39 PM
trinib20's Avatar
Default Re: please help me B16b wont stay running
Did you use the Stock B16b ecu ?
try a different IAC first
Old Oct 17, 2012 | 01:04 AM
lovehondas's Avatar
Im using the b16b ecu and I also swapped in a iac from an b18b and nothing
Old Oct 17, 2012 | 03:09 AM
rd91sib18c5r's Avatar
Can you keep it running giving it gas? Is the vacume hose from the fpr hooked up can't tell in pic.
Old Oct 17, 2012 | 03:14 PM
lovehondas's Avatar
In the picture it wasn't hooked up because I just got done cleaning it. I took the iacv and cleaned it and now the car idles for 5-6 seconds with the plug on. Someone give me some ideas please.
Old Oct 17, 2012 | 08:14 PM
JDM4mee's Avatar
Are you sure all the plugs have been connected to the right sensor...
IACV = black/yellow
blue/yellow
ECT = red/white and green/white
Old Oct 17, 2012 | 09:08 PM
EsotericImage's Avatar
Retired Moderator
tps and iavc usually get mixed up
Old Oct 17, 2012 | 09:30 PM
viperjng's Avatar
Hi,
Can't help with your issue but just wanted to say very clean and nice looking engine bay.
Jignesh
Old Oct 18, 2012 | 01:05 AM
lovehondas's Avatar
they are 2 completely different plugs, you probably mean tps and map
Old Oct 18, 2012 | 05:50 AM
2point1's Avatar
i think you mean map and tps or iacv and iat........op i need pics of the loose wires to help you more.....
lovehondas
Oct 25, 2012 09:56 AM
a1320honda
Apr 17, 2007 04:39 PM
Si_chRis
May 19, 2006 08:19 AM
crush
Jul 5, 2005 07:41 PM
