Hard starting..FJO reading 15/16 with car off....
Old Oct 17, 2002 | 05:27 PM
niedejb's Avatar
Default Hard starting..FJO reading 15/16 with car off....
Went out for a spin tonight and stopped to talk to a bud. Turned the car off...timer took over. Idled for the 1.5 min like normal (FJO @ 14-14.5, pressure at 36 psi).
Car turned off and not two seconds later I go to take off and it wouldnt start. Pressures 32 or so and the FJO is at 15!. Tried again and nothing. Waited for a couple of min and watched the FJO count up to 20 (where it reads at 0% throttle). After it got to 20 the car started.
Any insight?
Setup: 500cc RC's, 255 Walbro, 4:1 FMU, VAFC (non hack)
Old Oct 17, 2002 | 06:17 PM
niedejb's Avatar
Default Re: Hard starting..FJO reading 15/16 with car off.... (niedejb)
Old Oct 18, 2002 | 03:07 AM
niedejb's Avatar
Old Oct 18, 2002 | 01:49 PM
niedejb's Avatar
Old Oct 18, 2002 | 08:28 PM
bmm89's Avatar
not sure.. but normal to see 15/16 right after engine turned off from idle, what is it usually?
Old Mar 17, 2003 | 05:29 PM
mskibbz-T's Avatar
Default Re: Hard starting..FJO reading 15/16 with car off.... (bmm89)
Is it true the FJO shows A/F of 20.0 when you are at 0% throttle? I was worried my EMS had been using my O2 feedback on decel because I kept getting A/F = 20.0 when decellerating at 0% throttle after I disconnected my stock O2 and installed the FJO unit(but not hooked up to my EMS, just for testing the FJO install)
[Modified by mskibbz-T, 5:20 AM 3/18/2003]
Old Mar 18, 2003 | 01:12 PM
mskibbz-T's Avatar
Default Re: Hard starting..FJO reading 15/16 with car off.... (mskibbz-T)
ttt
Old Mar 18, 2003 | 01:16 PM
niedejb's Avatar
Mine reads 20 at 0% on decel on FMU, VAFC, and 500cc RCs.
Old Mar 18, 2003 | 01:23 PM
mskibbz-T's Avatar
Thanks, I was pretty worried there
SovXietday
Feb 27, 2007 03:49 PM
Westrock2000
Mar 22, 2003 04:28 AM
Big Phat R
Sep 23, 2002 05:10 PM
