S Trim Weight Versus SI trim weight 1993 Honda Del Sol
Old Oct 15, 2012 | 09:12 PM
koolhut's Avatar
Default S Trim Weight Versus SI trim weight 1993 Honda Del Sol
I have been doing some research about my 93 Honda Del Sol SI Trim, manual, in regards to how much it weights. I found that the S trim, same year, weights roughly 100 pounds less than the SI trim, and I am trying to figure out where that weight came from? I know the SI trim got some better electronics, rims, brakes, engine but hardly enough change to gain over 100 pounds. For the sake of curiosity, I am just wondering if anyone knows where that extra weight came from as I have looked through specs of both to no avail.
Thanks,
Matthew
Old Oct 16, 2012 | 07:33 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: S Trim Weight Versus SI trim weight 1993 Honda Del Sol
Different motors and tranny. "S" comes w/ a non-VTEC 1.5L SOHC engine while the "SI" comes with a D16z6 1.6L SOHC VTEC. That's where the weight difference is.
Old Oct 16, 2012 | 08:25 AM
JuggerNaut-CTR's Avatar
The "S" is the base model, no power luxuries. Between being all manual, having no a/c, no cruise control, being on 13 in rims, and different suspenision/brake components...thats were the weight difference mostly is. It does however matter if the car is auto or not. Where ever you got your data should state weight for auto version and manual version. Auto trans is significantly heavier than manual, but no 100lbs.
Old Oct 17, 2012 | 03:27 AM
NVturbo's Avatar
O.G. triple O.G.
You must have never owned a Del Sol. They do come with A/C and power windows. The suspension is all the same, whether it's a "S", "SI" or "DOHC VTEC". You might want to check your sources before making lame assumptions.
Old Oct 17, 2012 | 06:00 AM
^agreed...was a lame assumption, the 'S' must be the best "base" model honda out there lol
Old Oct 17, 2012 | 06:05 AM
NVturbo's Avatar
O.G. triple O.G.
don't sweat it. haha
Old Oct 17, 2012 | 04:53 PM
salaamq's Avatar
The Si's had strut bars added on to them, and rear disk brakes.
The VTEC's had rear strut bars added on, also a chassis bar up front, and stiffer springs.
Some of them didn't have a/c.
Old Oct 18, 2012 | 03:00 AM
NVturbo's Avatar
O.G. triple O.G.
Factory A/C is an option....mostly for Northern Honda dealerships. Additional parts here and there do add up to 100lbs.
Old Oct 18, 2012 | 03:58 AM
jbpnoman's Avatar
FYI, rear disc brakes are lighter than rear drums.
Old Oct 18, 2012 | 03:15 PM
salaamq's Avatar
Yes I know, just stating the model differences.
94eg2sol
Feb 8, 2006 07:24 PM
sinjin22ap
Dec 28, 2004 12:16 PM
EG_HB
Oct 29, 2002 03:46 AM
thefungus
Aug 24, 2001 12:31 PM
