HELP!! Fixed broken timing belt - now it doesn't run!!
Old Oct 15, 2012 | 07:36 PM
Far-North's Avatar
Icon2 HELP!! Fixed broken timing belt - now it doesn't run!!
Help!!
I don't understand WTF is going on. 1990 Honda Accord F22 5 speed 242,000 miles. Bought this as a cheap commuter, shortly thereafter timing belt broke.
Replaced timing belt, and all other relevant parts that typically get changed with this job, waterpump, other belts, etc.
Here's the thing, put it all back together, and I can''t make this thing run. Went back to basics, suck, squeeze, bang, blow.
Checked compression, 140 lowest, 160 highest, not even and new, but OK. All timing marks are lined up, triple checked. Took off valve cover and verified #1 and all sequences are correct. Checked timing with timing light while cranking, light indicates timing good. New spark plugs, checked spark, all four good spark. Checked fuel pressure, 40psi at rail. Checked fuel injectors with light, all work. Removed distributor, cleaned, replaced rotor, cap good.
Everything looks good, all other electrical systems work, checked all fuses everything is good...............but I cannot make it run!!!
HELP!!
Old Oct 15, 2012 | 07:39 PM
doctorbee's Avatar
Default Re: HELP!! Fixed broken timing belt - now it doesn't run!!
is your firing order correct?
Old Oct 15, 2012 | 07:40 PM
doctorbee's Avatar
also try squirting starting fluid into the intake and cranking it.
Old Oct 15, 2012 | 08:46 PM
Far-North's Avatar
Checked the firing order, it is correct, I did not try starting fluid, but I did try "pull starting" it, 2nd gear at 1200 rpm, still no go....
Old Oct 15, 2012 | 09:24 PM
doctorbee's Avatar
you can use gas instead of starting fluid but be VERY CAREFUL, don't put too much and watch your eyebrows
Old Oct 15, 2012 | 09:48 PM
Far-North's Avatar
While cranking the engine over, it acts like it wants to run, firing every once and a while. Sometimes, while cranking, it kicks back. I do not have any starting fluid, but will try some tomorrow. Is there some electrical reset or something I am unaware of? I have checked the wiring and the grounds. Correct me if I'm wrong, but if the ECU was not working correctly, I would have no spark, or injector impulse, which I have. AARRGGHH
Old Oct 16, 2012 | 04:49 AM
cctgene's Avatar
Check to make sure that your rotor is indeed pointing to the number one spark plug wire when the number one cylinder is at TDC.
Old Oct 16, 2012 | 05:13 AM
JuicedUpRice's Avatar
is it sputtering after a few rotations while cranking?
have you done the valve lash?
you said you changed everything typical of a broken timing belt.did this include the valves?leakdown test to make sure none of them got bent when it broke..
140 as the lowest compression # is a bit low..
Old Oct 16, 2012 | 05:20 AM
forted's Avatar
Sounds like your timing is off, put the engine on TDC cylinder 1 and check that your rotor points to the wire on the dist cap that goes to the number one cylinder.
Old Oct 16, 2012 | 06:04 AM
djkurious's Avatar
This. I been there and done this before! Timing was off on Cam side. Check all marks
Old Oct 16, 2012 | 12:27 PM
Far-North's Avatar
So here it stands, I did verify that the rotor is pointed at the # 1 position / plug, verified plug wires, verified correct cam timing by marks on cog-belt pully, the marks even with the head, and removed the valve cover to verify that the valves are all closed when at TDC.
As mentioned earlier, when cranking, it makes an attempt to run, but never actually starts.
I have not done a leakdown test, but will, and will again verify all timing marks.
Old Oct 16, 2012 | 04:50 PM
StreetLimitz89's Avatar
Dumb question.... but have u checked your crank sensor? Is it fully plugged in? Sou DS to me its getting a small voltage but not enough to reference the distributor to fire.... also... check fuel ...... just saying.... I've just read a lot about timing marks and distributor.....
Old Oct 16, 2012 | 05:47 PM
Fred Demara's Avatar
If your belt broke, there is a very good chance your valves are bent. I believe the f22 is an interference engine - meaning, the valves protrude into the cylinder bore. Your timing belt (when it's in time) keeps your valves from coming into contact with the piston. If a valve hits a piston, it'll bend. If a valve bends, you'll lose compression in that cylinder.
I've heard a few stories about belts breaking and the person did NOT try to turn the engine, and the valves did not bend. You have to do a leakdown, my guess is you got some bent valves, and it's time for a head job.
Let us know what it turns out to be - fingers crossed for you
Old Oct 31, 2012 | 01:57 AM
Far-North's Avatar
Sorry it's been so long in getting back to this, I work shiftwork.
First, thank you all for your advice.
That said, we finally got it. Here you go:
Went back to the basics, Suck, Squeeze, Bang, Blow. Since we knew that we had compression in all 4 cylinders, spark and fuel, we kept looking at the timing. Pulled out #1 plug, VERIFIED TDC, realized that the timing mark on the flywheel was about 6o degrees off, but there was a faint hand scratched mark where it should have been. (AHA moment) Re-set the timing belt and viola started right up first try. DUH.
Lessons learned: Don't trust the marks. Some douche before you may have mis-assembled something. Always verify all settings, such as TDC.
On a positive note, no crashed valves, it runs as good as could be expected for a beater with 242,000+ miles on it.
Old Oct 31, 2012 | 01:30 PM
MAD_MIKE's Avatar
MM Gruppe B
Thats a bit disconcerting.
I was fairly sure that regardless of year, all F22s still kept the timing marks in the same spot on the flywheel, even on the later 94-97s that used the harmonic damper.
Are you sure it was 60°? If it's closer to 45° someone may have installed the flywheel off by a bolt hole, and you may in fact be missing a couple of bolts. Unless some munchkin 'opened' the holes up to make them work.
That is spooky.
CesLNX
22
Apr 8, 2013 09:24 PM
toolboxtony
Jul 18, 2011 03:23 PM
pimpwagon
Nov 12, 2010 08:41 AM
Sturmcrow
Jul 11, 2005 04:50 PM
Bert1
Nov 23, 2001 01:20 PM
